Accessing Recovery Mode on Arielli 58 Android TV 9 with Stuck Google Screen
fathifaten2 5304 1
  • Reset button method to enter recovery mode
    #2 21045294
    MominaRizwan
    Accessing recovery mode on an Arielli 58 Android TV with a stuck Google screen can help you troubleshoot the issue. Here's how you can do it:
    Turn off the TV: If possible, try turning off the TV using the remote control. If it's unresponsive, you may need to unplug it from the power source.
    Locate the Reset Button: Look for a small reset button on your Arielli 58 Android TV. It's usually located either on the back or side of the TV. The reset button may be recessed, so you might need a small tool like a paperclip or pin to press it.
    Press and Hold the Reset Button: Use the paperclip or pin to press and hold the reset button for about 10-15 seconds. This action will force the TV to restart and may boot it into recovery mode.
    Access Recovery Mode: Once the TV restarts, keep an eye on the screen for any indication that it's entering recovery mode. This might be indicated by a different logo or message on the screen. If you see any such indication, release the reset button and wait for the TV to boot into recovery mode.
    Navigate Recovery Menu: Once you're in recovery mode, you may see a menu with options like "wipe data/factory reset" or "reboot system now." You can use the remote control's arrow keys or buttons to navigate through the menu options.
    Perform a Factory Reset: If you're unable to resolve the issue through other means, you can try performing a factory reset from the recovery menu. This will erase all data and settings on the TV, returning it to its original state. Use the remote control to select the "wipe data/factory reset" option and confirm your choice.
    Reboot the TV: After performing any necessary actions in recovery mode, select the "reboot system now" option to restart the TV.
    If you're unable to access recovery mode using the reset button method, you may need to refer to the user manual of your Arielli 58 Android TV for alternative methods or contact Arielli customer support for assistance.
