Arielli 32N218T2 Stuck on Wisdom Cloud Screen—Firmware Needed for TP.SK513S.PB818(T)
themibguy123 873 0
  • Searching for correct USB firmware and naming convention
    #1 21702777
    themibguy123
    My Arielli 32N218T2 TV is stuck on the Wisdom Cloud screen after a botched launcher change. And I want to install the firmware with a USB but cannot find it. The board and panel are TP.SK513S.PB818(T) and LQ315T3HC64. I would appreciate your help a lot.
    AI: Have you already tried any specific firmware files for the TP.SK513S.PB818(T) board? If so, which ones and what happened when you tried them?
    No I have not.
    AI: Can you describe the exact steps you’re using to try to install the firmware via USB (for example, how you’re preparing the USB drive and what buttons you’re pressing on the TV)?
    Formatted the drive to FAT32 and am currently searching for the proper firmware and naming convention for this TV.
