Error when uploading JSON file when installing Google Assistant on Armbian
lisman 510 2
  • #1 20978539
    lisman
    Hello, I have a problem installing Google Assistant on Armbian.
    During the final stage of uploading the JSON file, this problem emerges:
    attached
    • problem z json.txt (2.57 KB) You must be logged in to download this attachment.
  • #2 20978846
    JacekCz
    Help: 760
    Rate: 1464
    Something is not installed / incorrectly installed.
    Exception quite clearly indicates what is missing
    I do not know these software
    And that it is revealed during sending, it is such a beauty is the intepreter, it has nothing to do with the act of sending itself.
  • Suspected missing library or misconfigured JSON file
    #3 20978903
    lisman
    I make the assistant according to the instructions given on the Google site.
    I think there is a library missing, or this JSON file is misconfigured on the Google Developer site.
    I have installed it several times, even some other ways I found, and also could not install this assistant.
    The other ways consisted of installing from a script, on this other method again other errors were.
    I went back to this version of the installation from the Google site.
