[Solved] Correct Firmware for HAIER LE32M600C with SSDV3241-ZC01-01 Main Board
franbuyz 9423 6
  • #1 21063689
    franbuyz
    I'm looking for the firmware from HAIER LE32M600C, I've tried a dump from the Web but the screen is in mirror mode and bad colours, so wrong panel info.
    TV model: HAIER LE32M600C
    Chassis (Main Board): SSDV3241-ZC01-01
    Panel: LSC320AN02
    Thanks in advance.
    billobirillo
    Help: 338
    Rate: 796
    hi!
    here is the file
    • U6.BIN (8 MB) You must be logged in to download this attachment.
  • USB update requires Image.save file
    #3 21064975
    franbuyz
    Thank you very much for the file.
    I have tried to install it via USB and it doesn't work, I don't know if that file can be installed via USB.
    What I do is create a folder on the USB called usbflash and in that folder I copy the U6.BIN file.
    On this TV, the only firmware that has worked for me is one that included two files: Image.code.bin and Image.save. But that firmware is for another panel and the image is rotated and with strange colors. Without the Image.save file the update fails with all firmwares.
    I have attached the file that includes the Image.code.bin and Image.save files, I don't know if I could use the Image.save file with other firmware. I don't want to permanently break the television.
    • Haier LE32M600C SSDV3241-ZC01-01.zip (5.57 MB) You must be logged in to download this attachment.
    billobirillo
    Help: 338
    Rate: 796
    the file U6.bin is used for programming the spiflash 25Q64
  • #5 21065531
    franbuyz
    Thanks again, but I was looking for the firmware to update from USB, the television works and allows you to use that method, which is easier and safer than programming the SPI.
    Unfortunately now I don’t have a programmer for the SPI Flash 25Q64.
  • #6 21066884
    franbuyz
    I finally dared to edit the files to do a USB update and everything worked fine.
    I format a USB in FAT32 and copy the usbflash folder with the Image.code.bin and Image.save files inside, then update from the TV menu.
    I attach the files that I have used for my TV.
    Panel: LSC320AN02
    • Haier LE32M600C SSDV3241-ZC01-01 LSC320AN02.zip (5.36 MB) You must be logged in to download this attachment.
  • #7 21066891
    franbuyz
    After the USB update the TV works again.
The discussion revolves around finding the correct firmware for the HAIER LE32M600C television, which utilizes the SSDV3241-ZC01-01 main board and LSC320AN02 panel. The original poster experienced issues with a firmware dump that resulted in a mirrored screen and poor color quality. Several users contributed by sharing files and methods for updating the firmware via USB. The successful method involved formatting a USB drive to FAT32, creating a folder named "usbflash," and including the necessary files: Image.code.bin and Image.save. After following this procedure, the television was restored to working condition.
