Firmware Update for Thomson 55UA6406W TV - V8-NT67F01-LF1V378
mnjoao 4362 15
How can I update a Thomson 55UA6406W TV from firmware V8-NT67F01-LF1V378?
You can update the TV to firmware V8-NT67F01-LF1V509 using the provided upgrade link [#21304349] The update completed successfully, but the symptom stayed the same: the Thomson logo appears every minute and the backlight remains on [#21304593] That suggests the firmware was not the real cause and the main board may be faulty [#21304593]
  • #1 21304097
    mnjoao
    Level 4  
    Rate: 10
    Mark:THOMSON
    Model:55UA6406W
    Chassis (main board, components):40-NT67ES-MAC4HG
    LCD Screen/Panel (if exist): LVU550NDEL
    More information: Good morning, I come once again to ask for help to resolve the situation with this TV that needs to update the firmware, if anyone could send help I would appreciate it​
    THOMSON SOFTWARE:V8-NT67F01-LF1V378
    THANK YOU
    billobirillo
    Help: 338
    Rate: 797
    software version V8-NT67F01-LF1V509 and how to upgrade link .
  • #3 21304593
    mnjoao
    Level 4  
    Rate: 10
    thank you very much
    Added after 1 [hours] 3 [minutes]:
    the update was completed successfully, but it remains the same, the brand appears every minute, the backlight is always present,
    I assume the board is faulty, thanks anyway
  • #4 21844309
    filipemisa
    Help: 5
    Rate: 63
    olá
    o link esta off, pode postar de novo por favor
  • #5 21844352
    billobirillo
    Help: 338
    Rate: 797
    @filipemisa
    here is the software link
    link valid for 7 days
  • #6 21844782
    filipemisa
    Help: 5
    Rate: 63
    >>21844352
    muito obrigado
  • #7 21856082
    Croki73
    I'm looking for firmware V8-NT67F01-LF1V509.
    For a 55UG6420X1 TV.
    Thank you. The following links don't work.
  • #8 21856314
    billobirillo
    Help: 338
    Rate: 797
  • #9 21856624
    Croki73
    Transfer not found.
    Please check your link or try in a different browser. Sometimes browser extensions or software can alter the link.
    You can also contact the user who created this transfer to resolve the issue.
    I don't understand. Thank you.
    Added after 4 [minutes]:
    That's fine with me.
    It was Firefox.
    Thank you very much.
  • #10 21894385
    Bertrand44
    Hello guys! link is dead. Is it possible to get a new one for firmware V8-NT67F01-LF1V509? Thanks
  • #11 21894833
    billobirillo
    Help: 338
    Rate: 797
    @Bertrand44
    here is the sw link
  • #12 21895622
    Bertrand44
    Works fine. Thanks a lot.
  • #13 21916064
    TextureReporter1
    Hello guys! Link is dead. Is it possible to get a new one for firmware V8-NT67F01-LF1V509? Thanks
  • #14 21916189
    billobirillo
    Help: 338
    Rate: 797
    @TextureReporter1 here is the sw link
  • #15 21922269
    ChrisTv08
    >>21304097 >>21304349 I need a firmware recovery to put on a USB for Thomson 55UG6300, please.
  • #16 21922363
    Michał99
    Help: 140
    Rate: 345
    Start a new thread and provide the details as in #1, including photos of the panel and the model number.
Discussion about firmware update for a Thomson 55UA6406W TV with chassis 40-NT67ES-MAC4HG, LCD panel LVU550NDEL, and software V8-NT67F01-LF1V378. A newer firmware version V8-NT67F01-LF1V509 was shared along with an upgrade link, and the update completed successfully. However, the TV still showed the brand logo every minute with constant backlight, leading to the conclusion that the main board may be faulty. Later replies mainly requested the same firmware again after links expired, and one user asked for a USB recovery firmware for a Thomson 55UG6300.
