Panasonic TX-42AS520E - Does not start, backlight blinks three times
toudi85tv 9450 8
  • #1 16981769
    toudi85tv
    Rate: 14
    I have a problem with the Panasonic TV, as in the subject, after turning on the backlight blinks three times and the red diode begins to blink.
    At the start of the voltage look ok, the inverter goes 32V (as described) but can not start, the backlight will jump up to 100V (maybe more, I just do not know if the meter will keep up)
    After three blinks, the voltage of 32V disappears.
    When the TV Inverter is disconnected it also does not turn on (that's why I do not know whether to look for a reason), the front LED behaves the same and the 32V Inverter power supply also disappears after a while.
    The question is, where to look for the fault? Power Supply? Inverter? or motherboard?
    Should the TV start without Inverter?
    The voltage looks good in the power supply. I replaced the electrolytes.
    The fault started to happen gradually, that first there was no "picture" (maybe backlight), it was loud until it fell for good.
  • #2 16981847
    mirex
    Help: 1950
    Rate: 1990
    It's so hard to run the power supply itself in the right configuration to let at least one be sure?
    Please describe the construction of this TV. It should be in the first message.
    I suggest not to use the term inverter in LED equipment. It is true that the "inverter" is a broad concept and this module would also fit, but here it has been assumed that the inverter is associated with CCFL backlight.
    After all, it's probably better, albeit alien - LED driver.
  • #3 16981877
    toudi85tv
    Rate: 14
    Unfortunately, I do not know how to run it in the proper configuration, that's why I write as a beginner.
    Led driver is TNPA5935
    And the TNPA 5916 power supply
  • #4 16981920
    mirex
    Help: 1950
    Rate: 1990
    toudi85tv wrote:
    Led driver to TNPA5935
    And that's all there is? ;)
    And why two names, but each differently written?
    toudi85tv wrote:
    Unfortunately I do not know how to run it in the proper configuration, that's why I write as a beginner.
    It's rather in the so-called "Sandboxes" you should write. ;) After all, the documentation for these TVs is no problem.
    Error "3" is also described.
  • #5 16982910
    toudi85tv
    Rate: 14
    Excuse me, blank space by accident.
    Power supply: TNPA5916
    Driver Led: TNPA5935
    Motherboard: TNP4G568 2A
    T-con: V11 42 DRC 60Hz Control_Ver 0.3
    P / N: 6870C-0480A
    Still a wifi adapter that probably does not matter.
    I do not know if I am looking for a good job, but I have not found the documentation.
    How is it with this TV, should the rest of the LED driver disconnect the rest should start properly?
    mirex
    Help: 1950
    Rate: 1990
    KM26E.
    Plus "papers" without a diagram, only the list under the model TX-42AS520.
    • tx-42as520e chassis km26e.pdf (12.26 MB) You must be logged in to download this attachment.
    • TX-42AS500E Chassis KM26E.pdf (11.66 MB) You must be logged in to download this attachment.
    lisek
    Service technician RTV
    Help: 6353
    Rate: 6884
    * LED Driver TNPA5935 Panasonic chassis KM29 for TX-42AS520 / ... / TX-49DSU501
    IC7800 BD9483F
    See attachment, SM driver and tiles.
      :!: I recommend p.25 (trouble with Panasonic 2016, Technical Guide), est.
    You will read error 3 in SM, Col. mirex reported
    * usually 3 blinks - A Board SOS.
    You do not know or understand> go to the service.
    these modules are cheap on eBay.
    p.s
    For example, SM for chassis KM26, ch. 6 / i 7 Link
    - I recommend the Self Check mode
    • Panasonic LCD 2016 Technical Guide..pdf (1.83 MB) You must be logged in to download this attachment.
    • LED Driver TNPA5935 Panasonic KM29.pdf (3.74 MB) You must be logged in to download this attachment.
  • #8 16985320
    toudi85tv
    Rate: 14
    Thanks for the hints.
    One backlight diode is damaged, I found the whole strip, I already order.
  • #9 16989769
    toudi85tv
    Rate: 14
    a strap with diodes replaced, the television flashes up nice.
    Thanks again and best regards.
The discussion revolves around a Panasonic TX-42AS520E television that fails to start, indicated by three blinks of the backlight and a blinking red LED. The user reports that the power supply voltage appears normal at 32V, but the backlight voltage spikes to 100V before dropping. Various components are identified, including the LED driver (TNPA5935), power supply (TNPA5916), motherboard (TNP4G568 2A), and T-con board (V11 42 DRC 60Hz). The error code "3" suggests an issue with the A Board. After troubleshooting, the user discovers a damaged backlight diode, which, upon replacement, resolves the issue, allowing the TV to function properly again.
