Looking for TP.HV352T.PB753 Firmware Download and Installation Guide (allupgrade_an12_V3520N0E)
nenotafe 3213 5
  • #1 21603485
    nenotafe
    Hi there! I am no expert in this subject, I am posting this because of a friend who needs it. He's looking for firmware for "tp.hv352t.pb753", as well as how to install it. Says the file could possibly be named allupgrade_an12_V3520N0E_8G_512X2MB_sos.bin
  • #2 21613327
    gaokehe262
    The exact firmware must match the TV model (not just the board number).
    Check the TV’s label (back panel or settings menu) for the full model number (e.g., "TCL L40P2US", "Hisense 40H4", etc.).
  • #3 21693799
    youcef3232
    tp.hv352t.pb753 @ElektrodaBot
  • Firmware must match exact TV model and panel variant
    #4 21693810
    ElektrodaBot
    AI OpenAI ChatGPT4
    Help: 364
    Rate: 954
    Direct answer .
    - The board number TP.HV352T.PB753 alone is not sufficient - the firmware must be matched to the specific TV model, matrix (panel) used, memory and tuner configuration.
    - The file you are looking for has a typical rescue name for this platform: allupgrade_an12_V3520N0E_8G_512X2MB_sos.bin. It will only work if it is built for the identical board and panel variant as your TV.
    - Installation usually takes place in SOS mode from a FAT32 memory stick: .bin file in the root directory, switch on the TV with the power button on the casing pressed until the LED starts flashing rapidly; the whole thing takes 5-15 minutes.
    - Please provide: make and full model of the TV from the sticker, panel code (e.g. V390.../HV320.../ST3151...), symptoms (bootloop, logo freeze, black screen). Without this data it is not possible to indicate a safe batch.
    Detailed analysis and procedure .
    1) What you need to identify before you upload anything .
    - The full TV model from the back label and the production version (REV/Version/Code).
    - LCD/LED panel designation from the sticker on the matrix (e.g. BOE, CSOT, Innolux; codes like HV320..., V400..., V390...).
    - Memory configuration: usually 8 GB eMMC and 1 GB RAM (often 2 × 512 MB - hence the "512X2MB" in the file name).
    - Exact board designation: TP.HV352T.PB753 + any suffixes/revisions from the white stickers.
    - Symptoms: does the TV enter the system, or just the logo, or no backlight, or no picture with sound, etc.?
    Why this is critical:
    - Each panel requires different LVDS/eDP timing, colour mapping and backlight configuration. Incorrect batch = no picture, inverted/negative, white screen, flicker or no backlight.
    - Different variants have different remote control codes, Wi-Fi/Bluetooth drivers, tuner configurations (DVB-T/T2, DVB-C, DVB-S/S2).
    2) About the file name "allupgrade_an12_V3520N0E_8G_512X2MB_sos.bin" .
    - allupgrade ... sos.bin - "rescue" (full) image, run without running Android, directly from the bootloader.
    - an12 - compilation line under Android 12 for this platform.
    - V3520N0E - SoC/SDK branch number of this board family.
    - 8G_512X2MB - target memory map: 8 GB eMMC, RAM 2 × 512 MB.
    Note: packages available on the web with similar names, but with a different panel profile, can "get up" and still not give an image or block further updates (incompatible keys/secure boot).
    3) Preparation and upload (SOS mode via USB) .
    1. flash drive 4-16 GB, formatted as FAT32 (MBR, default cluster size).
    2. Copy exactly one file: allupgrade_an12_V3520N0E_8G_512X2MB_sos.bin to root directory.
    3. TV disconnected from the mains. Insert the memory stick into the USB port (usually USB1/USB 2.0).
    4. hold the power button on the TV casing (or joystick - position "OK/Enter"). While holding the button, connect the power.
    5. signals the start of the upgrade: fast flashing of the standby LED, sometimes the screen "Upgrading...". Release the button only after the sequence has started.
    6. do not disconnect power for 5-15 min. The TV will reboot itself when finished.
    7. the first startup is longer; do a factory reset from the menu (to clear NVM/parameters from the previous version).
    If the update does not start:
    - Use another flash drive (USB 2.0, small capacity), a second USB port.
    - Make sure of the file name; on some revisions, variants without "_sos" or with a different suffix are also accepted, but only if the manufacturer has so provided. Do not rename at random.
    4) After uploading - panel service settings .
    If the picture is incorrect (missing, negative, wrong orientation, stripes), enter the service menu and select the correct panel type:
    - Input type: Source/AV → 2580 or Menu → 1147 (combinations vary between OEMs).
    - Set: Panel Type (exact model), LVDS Map/Swap, H/V Flip, backlight PWM brightness.
    - Save and reboot.
    5) Troubleshooting .
    - LED flashes but no progress on screen: possible panel incompatibility - process may be running 'blind'. Check image after reboot, possibly correct in service.
    - No response to flash drive: potentially faulty bootloader in SPI or active security (secure boot only accept signed images).
    - Remote control does not work after flash: different IR/BT map in firmware. Sometimes it is possible to change the type of remote control in service.
    6) Emergency routes (if SOS does not work) .
    - Programming of SPI memory (e.g. 25Q64/25Q128) with CH341A programmer - uploading correct bootloader (dump from identical board).
    - Programming eMMC via adapter (ISP) or test connector - advanced, requires some "full dump" under identical model/panel.
    - UART (TTL 3.3 V) - boot logs make it easier to assess whether the bootloader sees USB and why it refuses.
    7) Common pitfalls .
    - "Nearly matching" batch with same PB753 but different panel - TV seemingly starts but with no picture or errors; risk of permanent NVM mismatch and OTA lock-up.
    - Power supply during flashing - voltage spikes = high risk of "stalling"; use a power strip with protection/UPS.
    - Copies with newer protection - will only accept images signed for the brand/region.
    What I need from you to select the correct batch .
    Post in thread (ID 4129784):
    - Photo of rear TV label (full model, SN, version).
    - Photo of the stickers on the motherboard (TP.HV352T.PB753 + all stickers with codes).
    - Panel code from the matrix (photo or transcribed exactly).
    - Symptoms and current software version (if readable), date of problem.
    Based on this, I will check for compatibility and indicate a specific safe image or alternative.
    If you already have an "allupgrade_an12_..._sos.bin" file, upload its checksum (SHA-256/MD5) - I'll compare if it's the right package for your setup.
  • Requesting panel code to match TP.HV352T.PB753 firmware
    #5 21878706
    edel9004
    Hello everyone,
    I need the firmware for my TV with mainboard TP.HV352T.PB753 (N).
    TV brand and model: Royal RLED 4325 (43 inches, Full HD 1920x1080)
    Mainboard: TP.HV352T.PB753 (N)
    Symptoms: The TV gets stuck on the "Smart Cloud" logo after the Royal logo appears, then restarts and stays in that loop.
    I believe the firmware file I need is: allupgrade_an12_V3520N0E_8G_512X2MB_sos.bin
    But I understand I need the version that matches my exact LCD panel. Could you please help me find the correct file for my panel?
    I will open the TV and provide the panel code. What specific information do you need from the panel sticker?
  • #6 21884154
    Defarman
    Thanks zpe4050,i need this file tio for lc32
