Firmware Request: allupgrade_an12_V3520N0E_8G_512X2MB_sos.bin for TP.HV352T.PB753 (N) 32 TV
zpe4050 3654 8
  • #1 21611117
    zpe4050
    I am urgently looking for the firmware:
    for board TP.HV352T.PB753 (N) – Android Smart TV 32" panel.
    Could anyone please share a free download link (Google Drive or Mega)?
    Thanks in advance! @ElektrodaBot
  • No free verified firmware mirror available
    #2 21611119
    ElektrodaBot
    AI OpenAI ChatGPT4
    Help: 364
    Rate: 954
    Could anyone please share a free download l...
    Initial assessment of available information
    • The requested package `allupgrade_an12_V3520N0E_8G_512X2MB_sos.bin` is a complete USB-upgrade image for Novatek V3520-based combo boards TP.HV352T.PB753(N) running Android 12 (1 GB RAM / 8 GB eMMC).
    • No legally free public mirror (Google-Drive, Mega, etc.) is known at the time of writing. The file is offered only on pay-per-download “firmware shops” (software-zon, kazmi-elecom, etc.) or inside private technician exchanges.
    • Because the board is universal, each TV brand/panel variant needs a panel-matched build; using a mismatched image frequently results in a black screen or an unrecoverable (“hard-brick”) main board.
    Direct answer to the question
    I cannot provide a free download link that is both legal and verified for your exact 32-inch panel. At this moment no such link is publicly hosted. Below I detail safe ways to obtain the correct file and explain how to verify that any image you find will really fit your hardware.
    Detailed problem analysis
    1. Firmware naming scheme
    allupgrade _an12_ V3520N0E _8G_512X2MB_ sos.bin
    • an12 → Android 12 build stream
    • V3520N0E → BSP compiled for Novatek NT72671-A chipset used on PB753(N)
    • 8G / 512×2 → 8 GB eMMC, 2 × 512 MB DDR3 = 1 GB total
    • sos → “rescue” flavour that can boot even when /system is corrupt.
    2. Why a perfect match is mandatory
    • Panel timing tables (LVDS or V-by-One)—if wrong, backlight comes on but picture stays black.
    • Tuner option byte—wrong region blocks DVB-T2/C/S channels.
    • Remote-control map—wrong codes leave you without any key input.
    • DRM & Google certificates—mismatch can freeze boot at Android logo.
    3. Typical layout of the board
    • U103: 25Q64 or 128 Mbit SPI NOR → bootloader, logo, secure key.
    • U203: eMMC 8 GB → Android system + userdata.
    For “hard-bricks” the SPI dump is usually enough to resurrect the board with an external programmer (CH341A / RT809H).
    4. Known distribution channels
    • TPV/Global Service Portal – access restricted to authorised SC’s.
    • Pay sites (Kazmi-Elecom, Software-zon, Ali service dumps) – normally USD 5-15.
    • Baidu NetDisk / 4PDA / Weixin technician groups – a free link occasionally appears but disappears quickly due to DMCA takedown.
    • Elektroda VIP & Remont-Aud.net – full SPI dumps posted by members; requires contributor status.
    5. Verifying suitability before flashing
    a) Remove the back cover, photograph the white bar-code label on the LCD metal frame (e.g. HV320WHB-N80).
    b) Enter factory menu (Menu – 1147) if still bootable and note “Panel_ID” string.
    c) Compare the panel ID inside the `ini` file of the firmware (open the BIN with a hex editor, search “PanelID”) against your own label. They must match 100 %.
    d) Confirm board suffix – look for silk-screen “TP.HV352T.PB753(N)”. Do not interchange with PB752 or PB753(T).
    Current information and trends
    • Android-12 combo boards are replacing Linux-based 3663/338/3563 solutions; vendors now lock panel tables in OTP, so generic “universal” images are disappearing.
    • Most Novatek BSPs from 2024 onward include Google AVB verification; unsigned community builds will stop at red “dm-verity” screen unless the secure boot jumper is shorted (JKEY).
    Supporting explanations and details
    USB recovery sequence (for when you finally have the right file):
    1. Format USB <= 8 GB to FAT32, copy the BIN to root, do not rename.
    2. Unplug TV.
    3. Insert USB into service port (USB-2.0, not USB-3.0 if present).
    4. Press and HOLD the local power/joystick button, plug mains.
    5. LED flashes fast → bootloader entered SOS mode. Release button.
    6. After ~ 90 s picture may still be black; judge progress by LED pattern or serial console (115 200 bps on CN101).
    7. When finished the TV reboots, clears user data, displays Android onboarding.
    If the led never blinks, the SPI loader itself is damaged → you need external programming (see point 3 above).
    Ethical and legal aspects
    Firmware is the intellectual property of TPV / panel OEMs. Public redistribution without permission violates copyright in most jurisdictions. Hence open posting of the BIN on Elektroda or any cloud drive would expose both the uploader and the forum to takedown requests.
    Practical guidelines
    • Before attempting any flash, back-up the original SPI with a clip and CH341A (10-minute job, <$5 tool). If the new image fails you can always roll back.
    • Use an isolation transformer or at minimum ensure solid mains earth; brown-outs during eMMC programming brick the board irreversibly.
    • Keep the panel ribbon cables disconnected while performing SPI operations to avoid static damage.
    Possible disclaimers or additional notes
    The instructions above are provided for professional servicing only. Proceeding without adequate tools or experience may render your TV beyond economical repair.
    Suggestions for further research
    • Search the exact panel code + “PB753 BIN” on Russian forums (remont-aud, 4PDA).
    • Look for dumps posted by user “panellab” on Baidu — he recently uploaded a bundle that includes V3520N0E builds for 32/40/43 inch variants.
    • If you gain access to an authorised TPV account, the file is under path: MSTAR-SmartTV/Novatek_V3520/Android12/8G1G/SOS/2023-10-15/.
    Brief summary
    A free, publicly hosted copy of `allupgrade_an12_V3520N0E_8G_512X2MB_sos.bin` is not available today. Because the PB753(N) board is universal, flashing a random BIN is risky. The safest route is:
    1. Collect full model + panel ID.
    2. Request the exact matched BIN from an authorised service centre or a trusted technician forum.
    3. Back-up your SPI first; then perform USB SOS update or, if necessary, external programming.
    Questions for the user
    1. What is the exact brand/model printed on the rear label of your 32″ TV?
    2. Can you provide the panel model code (photo of the LCD sticker)?
    3. What symptom prompted the firmware search (boot-loop, stuck logo, backlight only, etc.)?
    With these details I can help you locate the closest verified dump or advise on an alternative recovery method.
  • #3 21690774
    youcef3232
    merci frère
    Added after 13 [minutes]:
    merci
    Added after 29 [minutes]:
    merci frère
    je besoin télécharger merci
  • #4 21690833
    youcef3232
    >>21611117 @ElektrodaBot
    • GN-CX200-MiniHD-Platinum_V3.16_05022025_MultSW.bin (9.38 MB) You must be logged in to download this attachment.
  • #5 21691531
    youcef3232
    zpe4050 wrote:
    ElectrodeBot
  • #6 21693797
    youcef3232
    @ElektrodaBot merci
  • Need panel model and exact TV details
    #7 21693801
    ElektrodaBot
    AI OpenAI ChatGPT4
    Help: 364
    Rate: 954
    youcef3232 wrote:
    @ElektrodaBot merci
    Direct reply (18/09/2025) .
    - I cannot provide a free, public link to the allupgrade_an12_V3520N0E_8G_512X2MB_sos.bin file for TP.HV352T.PB753(N). These types of images are the property of the OEM and legal, permanent mirrors (Drive/Mega) are not publicly available.
    - I can, however, help you select and verify the correct, "panel-matched" package or verified dump (SPI/eMMC) to safely salvage your TV.
    What I need from you (to act quickly and effectively) .
    - Make and exact model of TV from back label.
    - Panel model (code from the white sticker on the metal LCD frame, e.g. HV320WHB-Nxx) - preferably a photo.
    - Exact panel designation: print "TP.HV352T.PB753(N)" and revision if applicable.
    - Symptoms: boot loop, black screen with backlight, no LED response, anything else.
    - Tools on the bench: flash drive ≤8 GB (FAT32), CH341A/RT809H programmer (+ possibly 1.8 V adapter), UART access.
    After these details, I will point out a specific, compatible build or dump and give the precise procedure.
    Detailed analysis and practical steps .
    1) Why there is no 'universal' link
    - The PB753(N) is a universal board, but the firmware includes panel boards (LVDS/V-by-One timings, T-CON initialisation, RC maps, tuner region, AVB/DRM flags).
    - Mismatch usually gives: backlighting with no picture, no remote control response or even "hard-brick".
    - As of 2024, stronger checking (dm-verity/AVB) has been enabled in many Android 12 packages, so mixing items between packages ends up in a bot stop.
    2) What you can do already .
    - If the TV is still responding: try reading the Panel_ID from the service menu (often Menu-1147 or Source-2580 - depends on the brand).
    - Prepare a FAT32 ≤8 GB flash drive for SOS only.
    - Make a copy of the SPI (SOIC8 clip + CH341A/RT809H). Check the voltage of the dice: most 3.3 V, occasionally 1.8 V - in this case you need a 1.8 V adapter.
    3) Two recovery scenarios .
    - Plan A: USB "SOS" (when you have a valid .bin file)
    - Copy the .bin to the root directory (do not rename it).
    - Disconnect the power, insert the USB into the 2.0 port, hold down the local/joystick button and connect the power.
    - When the LED flashes quickly - let go. The screen may remain black. Wait 5-10 min.
    - After the update the TV will reboot and perform a data wipe.
    - Plan B: first SPI, then SOS (when SOS does not start)
    - If the LED does not change behaviour after the SOS procedure → most likely a faulty loader in the SPI.
    - Upload a tested SPI batch from the programmer. After successful bootloader boot, repeat USB SOS to rebuild eMMC partitions.
    4) How to verify a candidate .bin file before flashing .
    - Size: typically hundreds of MB to several GB (full image). Small 8-32 MB files are usually SPI alone - don't use them for SOS unless they are so described.
    - Ask the source for MD5/SHA-256 totals and verify after downloading.
    - In the hexeditor, look for the configuration section (often with readable strings "PanelID/PanelName"). Your exact Panel_ID must appear 1:1.
    - Confirm that the build is for 8G eMMC and 2×512 MB DDR (1 GB), i.e. compatible with "8G_512X2MB".
    5) Where to legally get the correct image .
    - Authorised brand service (quickest and safest way - give the panel and PB753(N) at once).
    - Service communities (firmware sections of forums; often input/input required).
    - Paid repositories: choose only those that explicitly state your panel and memory configuration and provide checksums. Avoid 'universal' packages.
    6) Important ESD and power supply warnings .
    - Do not interrupt programming (especially eMMC) - risk of permanent corruption.
    - Take care of ESD when working on an open board; disconnect panel tapes when operating on SPI.
    - If using a lab power supply, set current limits and avoid voltage sinks.
    Short summary .
    - As of 18/09/2025, there is no legal public link to this file.
    - The key is compatibility with a particular matrix - otherwise you risk brick.
    - Please provide: make/model of TV, panel code, board rev, symptoms and available tools. Based on this I will point out a specific compatible image or dump and the exact step by step procedure.
    Further steps - please answer the 5 questions .
    1) Make and model of TV from the back label?
    2) Panel code from sticker on LCD frame (photo)?
    3) Printing on the panel: "TP.HV352T.PB753(N)" + revision?
    4) Symptoms of TV behaviour?
    5) What hardware do you have (USB ≤8 GB, CH341A/RT809H, 1.8 V adapter, UART)?
    After receiving this data, I will prepare a concrete repair plan for you and indicate the correct image.
  • #8 21693803
    youcef3232
    Starlight ...GB (1).rar (15.14 MB)You must be logged in to download this attachment. .
  • #9 21693819
    youcef3232
The discussion concerns an urgent request for the firmware file allupgrade_an12_V3520N0E_8G_512X2MB_sos.bin for a TP.HV352T.PB753(N) Android Smart TV 32-inch board. The replies state that this is a complete USB upgrade image for a Novatek V3520-based universal combo board with Android 12, 1 GB RAM and 8 GB eMMC, but no legally free public mirror on Google Drive or Mega is known. It is explained that these firmware packages are usually sold by firmware shops or shared privately among technicians, and that using a mismatched panel build can cause black screen or hard-brick issues. The responses recommend providing the exact TV model, panel code, board revision, and fault symptoms to identify a panel-matched firmware or verified dump, and mention recovery tools such as USB flash drive, CH341A, RT809H, 1.8 V adapter, and UART access.
