Hisense 32A5100F Firmware Request for TP.MS3663T.PB704 Mainboard (USB Update)
adrienlafugetracy 1863 2
  • USB update loops on wrong TP.MS3663T.PB708 firmware
    #1 21644653
    adrienlafugetracy
    I need the firmware for a Hisense TV, model 32A5100F, with mainboard TP.MS3663T.PB704.
    The TV is stuck in a boot loop (“Do Not Power Off Scan” message, upside down image) and does not accept the usual USB firmware I found for TP.MS3663T.PB708.
    I found that the correct file should be available on remont-aud.net, but I cannot access it due to their registration system.
    Could someone please share the correct .bin file (USB update version, not only SPI raw dump) for TP.MS3663T.PB704?
    Details:
    - TV: Hisense 32A5100F
    - Mainboard: TP.MS3663T.PB704
    - Panel: JHD315X1H61
    - Serial: 3TE32G2109GL0 1C2LA30554
    Thanks a lot in advance!
    AI: Have you already tried performing a factory reset or accessing the service menu on your TV to resolve the boot loop issue? If so, what was the result?
    There is no Reset Button on the TV, and the main power button is unresponsive same for the remote.
    AI: Could you please describe the exact USB update procedure you followed (e.g., file placement, USB formatting, TV response during update) and mention any specific error messages or behaviors you observed when attempting to use the TP.MS3663T.PB708 firmware?
    I have formatted the USB in FAT32, then placed the file directly at USB's root. Then I plugged the USB in the TV while not connected to AC, then I plugged the AC of the TV, the TV instantly switch on with the message upside down "DO NOT POWER OFF SCAN" with a progress bar loading from 0% to 100% infinitely. I also tried this while pushing the TV power button while connecting the AC, but same result
  • #2 21645343
    jeloi
    Help: 285
    Rate: 597
    Post defective bin for repair.
  • #3 21645468
    adrienlafugetracy
    Hello @jeloi,
    Thank you for your answer.
    Here is the file I have tried to use:
    Thanks a lot for your help!
    • HE32E5100FHTS.bin (5.38 MB) You must be logged in to download this attachment.
