Firmware for Vestel 17MB170 Mainboard with VES500QHND-2D-N41 Panel on Edenwood ED50C01HD-VE
jltrastero 1629 10
Where can I find the correct firmware for an Edenwood ED50C01HD-VE TV with a Vestel 17MB170 mainboard and VES500QNDH-2D-N41 panel after the wrong firmware caused a mirrored image?
Use the firmware package shared for the Vestel 17MB170 board with the VES500QNDH-2D-N41 panel; the panel code was corrected in the thread from VES500QHND to VES500QNDH, and the file was posted as a temporary files.fm link with the warning to try it at your own risk [#21655078][#21655083][#21655400]
  • Wrong firmware causing mirrored image on Vestel TV
    #1 21654865
    jltrastero
    I’m looking for the correct firmware for a TV using the following configuration:
    • Mainboard: Vestel 17MB170
    • Panel: VES500QHND-2D-N41
    • TV brand/model (Edenwood ED50C01HD-VE)
    AI: Could you please specify why you need the firmware—are you experiencing a particular issue with the TV, or is this for an upgrade or recovery?
    I have problems with the memory of my TV.
    AI: Do you know the current firmware version installed on your TV, or have you already tried updating or reinstalling the firmware?
    I've tried to install another firmware but the image appears duplicate (mirroring)
  • #2 21654938
    yokoono51
    Help: 171
    Rate: 314
    VES500QHND-2D-N41 ???
  • #3 21655078
    jltrastero
    >>21654938 >>21654865 >>21654938
    Sorry VES500QNDH-2D-N41
  • #4 21655083
    yokoono51
    Help: 171
    Rate: 314
    I have this;
    17MB170 panel VES500QNDH-2D-N41 Daewoo
  • #5 21655162
    jltrastero
    >>21655083
    Thank you, I will try, my TV is not working right now.
  • #7 21655636
    jltrastero
    Thank you very much!
  • #8 21729047
    ced0
    The link is dead. Can you repost, please?
    Thank you
  • #9 21862347
    Bleckos28
    Hello, I'm looking for firmware to reset my Edenwood TV, model: VES500QNDH-2D-N41, with VESTEL CODE: 23612345 and Motherboard: 17MB170. When I turn on the TV, everything lights up, but then I can't access the main menu; it displays a "memory almost full" message. I can't find any other way to reset the TV. Thank you for your help.
  • #10 21886310
    SergeP
    Bonjour, j'ai le même pb, avez-vous trouvé une solution ?
  • #11 21886428
    Bleckos28
    Hello, you can contact yokoono51 privately, who has a solution that helped me directly.
Discussion about finding the correct firmware for an Edenwood ED50C01HD-VE TV with Vestel 17MB170 mainboard and VES500QNDH-2D-N41 panel. The issue is a memory-related fault: the TV powers on, backlight comes up, but the main menu cannot be accessed and a “memory almost full” message appears. A wrong firmware attempt caused a duplicated/mirrored image, indicating panel or firmware mismatch. A matching firmware was shared for the 17MB170 with VES500QNDH-2D-N41 panel, with a warning to use it at own risk; later the link expired and was requested again. Another user reported the same problem and was advised to contact a private helper who had a working solution.
