Improving Range of 0.9–3 GHz Loop Antenna Using 0.22µF Disk Capacitor Design
327 8
  • 0.22 µF disk capacitor used as loop antenna
    #1 21659447
    Yalamati Ramojirao
  • #2 21659448
    Cody Miller
  • #3 21659449
    Olin Lathrop
  • #4 21659450
    Yalamati Ramojirao
  • #5 21659451
    Cody Miller
  • Suggesting smaller NPO capacitors or direct wire feed
    #6 21659452
    Bruce Carter
  • #7 21659453
    KISHORE KRISHNA
  • #8 21659454
    Hart Jones
  • #9 21659455
    Poarch Jones
The discussion addresses improving the range of a loop antenna operating between 0.9 and 3 GHz, designed using a 0.22µF disk capacitor with fixed lead length and spacing to capture RF signals from mobile phones. Suggestions include replacing the capacitor lead antenna with a small dipole or patch antenna for better performance, considering directional antennas with reflectors such as parabolic surfaces or simple metal cans to enhance gain. It is noted that the 0.22µF capacitor is large for GHz frequencies and may behave inductively, thus smaller capacitance values with NPO/COG dielectric types are recommended to achieve proper resonance. Directly using a wire cut close to a quarter wavelength adjusted for propagation velocity is advised for improved antenna efficiency. Additional tips include using pre-amplifiers to boost signal reception and adjusting antenna positioning. The importance of hands-on antenna building and characterization, supported by spectrum analyzer measurements and online resources, is emphasized for skill development.
