Best PCB Design Software with Superior Auto-Routing vs Altium Designer Experience?
444 9
What PCB design software has a better autorouter than Altium Designer, and what routing practices help get good autorouting results?
A clearly better free or shareware autorouter than Altium is unlikely, because good autorouters are expensive and need careful setup of constraints before routing [#21659674][#21659675] PADS is reported as more user-friendly than Altium, with later versions showing fewer autorouter misbehaviors, though some users still considered it a bit buggy [#21659675][#21659678] One reply recommends PADS over Altium mainly by personal preference, especially for easier constraint/rule setup and library handling [#21659678] For dense or critical designs, manually route the important nets first and use autoroute for the rest [#21659675] A Mentor Expedition user reported that, after lengthy constraints, the router could complete a complex DDR board to 99.x% in under 10 minutes, showing that a strong autorouter can be very effective when well constrained [#21659681]
  • Altium autorouter offers little practical time savings
    #1 21659673
    Francois De La Roche
  • Fan out connections and tune autorouter constraints
    #2 21659674
    Joe Wolin
  • Manual routing for critical nets before autorouting the rest
    #3 21659675
    Dorin Dragan
  • Auto-routing still failed on a 4-layer 200-net board
    #4 21659676
  • Asking whether PADS auto-routing matches Altium
    #5 21659677
  • PADS preferred for easier rules and libraries
    #6 21659678
    Dorin Dragan
  • #7 21659679
  • Autorouter as a tool, not a substitute for PCB review
    #8 21659680
    Ralph Pruitt
  • Mentor Expedition autorouter handled dense DDR routing
    #9 21659681
    Martin Thompson
  • PCB fabrication requirements and available options
    #10 21659682
    Alice Brain
The discussion focuses on the effectiveness of auto-routing features in PCB design software, comparing Altium Designer with alternatives like Mentor Graphics PADS and Expedition. Altium's integrated auto-router is often criticized for inefficiency and requiring extensive manual intervention and constraint setup to achieve acceptable results. Users emphasize the importance of carefully defining routing rules, constraints, and fan-out strategies to improve auto-router performance. PADS is noted for being more user-friendly in constraint management but may have occasional bugs; its auto-router has improved over time and is considered comparable to Altium's. Mentor Graphics Expedition is highlighted for handling complex, densely packed designs with multiple DDR RAM devices efficiently, completing routing quickly after thorough setup. Overall, high-quality auto-routers are expensive and require significant preparation, and manual routing remains essential for critical signals. The consensus is that no free or shareware tool currently surpasses Altium's auto-router, and the choice between Altium and PADS often depends on personal preference and familiarity.
