How to Verify Orcad Circuit Matches Real PCB Schematic and Ensure Accuracy?
177 10
How can I verify that my OrCAD circuit matches the original circuit and whether it is correct?
You need to share the actual OrCAD design file or a PDF/screenshot of the schematic before anyone can verify whether it matches the original circuit [#21659745] Based on the posted description, the circuit appears to be an oscillator and gate driver, and if the oscillator runs correctly it should drive the motor at different speeds [#21659747] If the motor causes supply noise, add an RC filter to U1’s supply [#21659747] For checking and simulation, use LTSpice and compare your design against a similar reference circuit instead of relying only on the original drawing [#21659747]
  • #1 21659737
    KUNAL DHAKATE
  • #2 21659738
    Siraj A
  • #3 21659739
    Otto Sponring
  • #4 21659740
    Mylene Tarquini
  • #5 21659741
    KUNAL DHAKATE
  • #6 21659742
    KUNAL DHAKATE
  • #7 21659743
    Cody Miller
  • #8 21659744
    KUNAL DHAKATE
  • #9 21659745
    Otto Sponring
  • #10 21659746
    KUNAL DHAKATE
  • Suggesting LTSpice simulation and RC supply filtering
    #11 21659747
    Otto Sponring
The discussion centers on verifying the accuracy of an Orcad circuit design against a real PCB schematic, specifically for a 12 V DC motor speed controller. The original poster seeks guidance on comparing the Orcad schematic with the physical circuit and confirming its correctness. Respondents request the actual circuit diagram or Orcad design files (.DSN) for review, emphasizing the need for proper documentation such as screenshots or PDFs. It is noted that without Orcad software, obtaining a .DSN file may be difficult. The circuit in question appears to be an oscillator and gate driver intended to control motor speed, with suggestions to consider adding an RC filter to the supply for noise reduction. An alternative recommendation is to use LTSpice, a free simulation tool, along with reference designs like those available from Linear Technology to simulate and validate the circuit before implementation.
