How to feed a 10Gbps signal into a 4:1 MUX using Simulink component
510 7
  • Clarifying serializer, FIR, and coaxial line setup
    #1 21659819
    SK M
  • #2 21659820
    Cody Miller
  • #3 21659821
    SK M
  • #4 21659822
    Cody Miller
  • Need sample rate and serialization strategy for Simulink MUX
    #5 21659823
    SK M
  • Counter-based 4:1 mux select with flip-flops
    #6 21659824
    Cody Miller
  • Clarifying equal 10 Gbps splitting across 4 MUX inputs
    #7 21659825
    SK M
  • Use a shift register to demultiplex the signal
    #8 21659826
    Cody Miller
The discussion focuses on simulating a 10 Gbps NRZ signal feeding into a 4:1 Current Mode Logic (CML) multiplexer using Simulink. The transmitter comprises a CML multiplexer, buffer, and driver, with the link operating at 10 GHz, requiring multiplexing of four 2.5 GHz data streams to form the 10 Gbps output. The main challenge is dividing the 10 Gbps serial data into four parallel 2.5 Gbps channels for the MUX inputs and performing the inverse operation at the receiver. This process is akin to serialization and deserialization (SERDES). A suggested approach involves using a counter with phase-shifted clock signals to generate selection signals for the MUX, combined with flip-flops to synchronize data. The concept of using a shift register clocked at a higher frequency to demultiplex the signal at the receiver is also discussed. The sample rate for eye diagram analysis in Simulink should correspond to the data rate (e.g., 10 Gbps). The discussion clarifies the difference between multiplexing and demultiplexing in this context and emphasizes the need for clock phase management and synchronization in the simulation model.
