How to Design a Circuit That Indicates When a Short Circuit Occurs?
213 9
How can I design a circuit that indicates when a short circuit or overload current occurs?
Detect the short circuit by measuring the circuit current and comparing it with a known reference current or the system’s specified current range [#21660220][#21660223] If the measured current increases above the reference, feed that difference to an indicator to show an overload/short condition [#21660223] If current measurement is not practical, compare the voltage instead, because when a short circuit occurs the voltage difference should be zero [#21660225] You can route that voltage through a comparator/op-amp or use a microcontroller to sense the condition and trigger an alarm or other indicating device [#21660225]
  • #1 21660217
    siti nazira
  • #2 21660218
    BHARADWAJ ACHARYA
  • #3 21660219
    siti nazira
  • #4 21660220
    Cody Miller
  • Assignment asks for cause investigation and prevention report
    #5 21660221
    siti nazira
  • #6 21660222
    siti nazira
  • #7 21660223
    BHARADWAJ ACHARYA
  • #8 21660224
    siti nazira
  • Suggesting voltage comparison or MCU alarm for short detection
    #9 21660225
    BHARADWAJ ACHARYA
  • #10 21660226
    Cody Miller
The discussion focuses on designing a circuit to indicate the presence of a short circuit by detecting abnormal current conditions. A short circuit is characterized by a low-resistance connection between positive and negative terminals, causing a high current flow. The suggested approach involves measuring the current in the circuit and comparing it to a predefined reference current that represents normal operating conditions. This comparison can be implemented using an operational amplifier configured as a comparator to detect when the current exceeds the safe threshold, thereby triggering an indicator. Alternatively, voltage comparison methods can be used, as a short circuit typically results in a near-zero voltage difference across certain points. For more advanced solutions, a microcontroller can be employed to sense current or voltage levels and activate an alarm or indicator accordingly. The key design challenge is establishing an appropriate reference current or voltage level based on the system specifications to reliably detect overload or short circuit conditions.
