Images not appearing after upload with Browse function—forum image upload issue
219 7
  • #1 21660295
    Frank Bushnell
  • Suggesting image format, size, or PDF upload workaround
    #2 21660296
    Steve Lawson
  • #3 21660297
    Frank Bushnell
  • #4 21660298
    Frank Bushnell
  • #5 21660299
    Steve Lawson
  • #6 21660300
    Steve Lawson
  • #7 21660301
    Frank Bushnell
  • #8 21660302
    Steve Lawson
The issue discussed involves images not appearing after upload using the forum's "Browse" function. The problem was traced to the image file format, as BMP files are not supported by the EEWeb image uploader. Converting the image from BMP to JPG resolved the issue, allowing successful upload and display. It was suggested that supported formats likely include GIF, JPEG, and PNG, which comply with HTML standards. File size and compression were also mentioned as potential factors, with recommendations to use compressed formats like GIF or 8-bit PNG for circuit diagrams. Additionally, uploading images as PDFs was proposed as an alternative, with Bullzip PDF printer recommended for Windows users to convert files to PDF format. The discussion also briefly touched on circuit design efficiency and LED current consumption, but the main focus remained on image upload compatibility and format issues.
