SCR Replacement in 250V 300W Speed Controller: Triac or Thyristor Compatibility?
546 6
  • #1 21660309
    Frank Bushnell
  • #2 21660310
    Frank Bushnell
  • #3 21660311
    Frank Bushnell
  • #4 21660312
    Frank Bushnell
  • Use an SCR replacement, not a triac
    #5 21660313
    Davide Andrea
  • #6 21660314
    Earl Albin
  • #7 21660315
    levent Iblis
The discussion addresses the replacement of a failed SCR (Silicon Controlled Rectifier) in a 250V, 300W power tool speed controller originally using a C106B1 SCR rated at 200V, which was underspecified for the application. The question is whether a triac or another thyristor with adequate voltage and current ratings can substitute the SCR, motivated by cost considerations. Clarifications confirm that an SCR is a type of thyristor, as is a triac, but the circuit design specifically requires an SCR. Replacing the SCR with a triac or a generic thyristor is not recommended due to the high voltage and specific control requirements of the circuit. The consensus is to use a proper SCR replacement with equal or higher voltage and current ratings to ensure reliable operation. The original circuit board and enclosure have sufficient space for modifications if needed, but the best practice is to source an appropriate SCR, such as those available from electronic component suppliers like Digi-Key.
