Correct Fuse Rating for 30W CFL Lamp With Power Factor Consideration?
285 7
  • Fuse sizing should account for CFL inrush current
    #1 21660365
    Robert Birch
  • #2 21660366
    Davide Andrea
  • Measure true load current and use a slo-blow fuse
    #3 21660367
    Kevin Parmenter
  • #4 21660368
    Steve Lawson
  • #5 21660369
    Robert Birch
  • #6 21660370
    Steve Lawson
  • Measure startup and fault current with a current probe
    #7 21660371
    DAVID CUTHBERT
  • Fuse should be about 2× the CFL load
    #8 21660372
    Steve Greenfield
Determining the correct fuse rating for a 30W CFL lamp requires considering not only the nominal current calculated by power divided by voltage (e.g., 30W/240V = 0.125A) but also the power factor and inrush current characteristics. Since CFLs can have a low power factor (around 0.5) and significant harmonic distortion due to their internal diode-capacitor circuitry, the actual current drawn can be higher than the simple calculation suggests. The fuse must accommodate startup surges (inrush current), so a slow-blow (time-delay) fuse rated at approximately twice the nominal current is recommended. Accurate fuse selection involves measuring the true current waveform using instruments like oscilloscopes with current probes or power analyzers (e.g., Voltech PM1000) to capture normal, startup, and fault conditions. Fuse ratings also depend on I²t characteristics to ensure the fuse does not blow during normal operation but will open under fault conditions. Consulting fuse manufacturers' application engineers (e.g., Littelfuse, Bussmann) and reviewing fuse derating guidelines is advised for precise selection.
