High Output 6V/12V LED Alternatives to 120W 230V PAR38 Bulbs and Battery Options
246 9
How can I replace a 120W, 230V PAR38 bulb with a low-voltage LED light source and battery pack that will run for about 8-10 hours?
Use a 12V high-power LED setup rather than trying to find a direct 6V/12V bulb replacement; one concrete example is the Bridgelux BXRA-W0802-00Q00, which gives 930 lumens at 12.2V and 1.05A, so three of them in parallel would produce about 2790 lumens, more than a 120W incandescent [#21660833] At that current level, the total draw is about 3A, so a 12V 30Ah sealed lead-acid battery is a reasonable choice for roughly 8-10 hours of runtime [#21660833] If size is not a problem, a standard 12V car battery can power enough LEDs for this kind of light output [#21660828] If you want something smaller, lithium-ion is the compact option, but you would need cells in series for 7.4V or 14.8V and then balanced charging [#21660828]
  • Sizing battery and low-voltage LED replacement for PAR38 lamps
    #1 21660825
    Neil Scrivener
  • #2 21660826
    Neil Scrivener
  • #3 21660827
    Calinoaia Valentin
  • Clarifying lighting requirements and battery options
    #4 21660828
    Joshua Bishop
  • #5 21660829
    Neil Scrivener
  • #6 21660830
    Joshua Bishop
  • #7 21660831
    Neil Scrivener
  • #8 21660832
    Samuel Sloan
  • 12V Bridgelux LED and 30Ah SLA battery sizing
    #9 21660833
    StrykerTECH
  • #10 21660834
    sunluxled
The discussion focuses on replacing 120W, 230V PAR38 incandescent bulbs with high output LED alternatives operating at low voltages (6V or 12V) suitable for battery power. Key considerations include achieving comparable luminous output to a 120W tungsten bulb (~2100 lumens) and ensuring 8-10 hours of battery runtime. Suggested LED solutions involve using multiple high-power LEDs such as the Bridgelux warm white BXRA-W0802-00Q00, which delivers approximately 930 lumens at 12.2V and 1.05A; three in parallel can exceed the target brightness. For power, sealed lead acid batteries like the 12V 30AH Powersonic PG12V28FR are recommended to provide sufficient capacity and runtime. Alternative battery options include 12V car batteries for larger setups or lithium-ion packs configured in series (7.4V or 14.8V) for more compact designs, though these require balanced charging. The importance of clarifying size constraints and lighting type (directional vs ambient) is noted. The discussion also touches on sourcing components from suppliers such as Rapid.
