12V Soil Moisture Sensor Circuit to Control 220V 18W Pump for Automatic Irrigation
234 8
  • #1 21661656
    Sarath Kumar
  • #2 21661657
    Cody Miller
  • #3 21661658
    Samir Guessmi
  • Recommend microcontroller control and proper pump driver
    #4 21661659
    Samir Guessmi
  • #5 21661660
    Samir Guessmi
  • #6 21661661
    Tekane Mopeli
  • Proposed PIC control algorithm for irrigation pump
    #7 21661662
    Mark Harrington
  • #8 21661663
    Mark Harrington
  • Microchip confirmed the assembler syntax issue
    #9 21661664
    Mark Harrington
The discussion addresses designing a circuit to control a 220V, 18W pump using a 12V soil moisture sensor for automatic irrigation. Recommended approaches include using a microcontroller (e.g., PIC16Fxx or PIC18Fxx) to process the sensor's analog or digital output and control the pump via an appropriate driver such as a relay or triac. Several external resources and schematic examples for automatic watering systems were suggested as starting points. The control logic involves reading soil moisture levels through ADC inputs, setting threshold levels (potentially via a learn switch), and activating the pump accordingly. Additional considerations include interfacing with stepper motors for pump control and serial communication ports for data acquisition. Code development advice emphasizes breaking down the schematic into functional blocks and implementing the control algorithm based on sensor input and user-defined moisture thresholds.
