Best Sensors and Microcontrollers for Automated Farm Irrigation System with Server Control
240 7
  • Requesting component suggestions for automated irrigation system
    #1 21662044
    Varoluu Prens
  • Distributed soil sensors with PIC daughter boards and I2C/CAN control
    #2 21662045
    Krishna Prayaga
  • #4 21662047
    Thomas Lepik
  • #5 21662048
    Varoluu Prens
  • #6 21662049
    Varoluu Prens
  • Plant-based sensing ideas for irrigation timing
    #7 21662050
    Steve Lawson
  • Concern about added complexity in portable irrigation system
    #8 21662051
    Varoluu Prens
The discussion focuses on designing an automated farm irrigation system that measures soil moisture and communicates with a server to optimize water usage. Key components suggested include soil moisture sensors that measure soil resistance, arranged strategically across the land (e.g., 30-35 sensors per acre). These sensors can be integrated into a voltage divider circuit connected to microcontrollers such as PIC or AVR. A hierarchical control system is proposed, with daughter boards reading sensor data and communicating via protocols like I2C or CAN to a mother board that manages irrigation decisions based on averaged sensor readings. The AVR GardenBot project is recommended as a practical starting point for development, offering well-documented examples and community support. Alternative innovative sensing methods discussed include measuring plant electrical resistance, galvanic responses, reflectivity in green or infrared spectra, stem bending resistance, and gas production ratios (CO2/O2) to infer plant water needs. While these novel approaches could enhance precision, they may increase system complexity. The goal is to create a scalable, portable system applicable to various crops and arid regions, with potential for commercial deployment.
