Why does negative feedback stabilize an operational amplifier?
900 14
Why does negative feedback make an op-amp settle to a stable, predictable gain instead of just saturating?
Negative feedback stabilizes an op-amp because the op-amp has very large open-loop gain, so even a tiny input difference drives the output in the opposite direction of that difference until the feedback reduces the difference toward zero. [#21661834][#21661832] In a non-inverting amplifier with a divider that feeds half the output back to the inverting input, the circuit reaches equilibrium when the output is twice the input, because that makes the two inputs equal. [#21661834] The output does not jump instantly; it changes as fast as its slew rate allows, and the feedback keeps correcting it as the output moves. [#21661839] If the output overshoots, the sign of the input difference reverses and the amplifier drives back the other way until it settles, unless it runs into the supply rails. [#21661839][#21661834] In practice, the inputs are treated as nearly equal because the input current is negligible and the remaining error is very small, not exactly zero. [#21661834]
  • Negative feedback drives input difference toward zero
    #1 21661831
    Craig Hickman
  • #2 21661832
    Calinoaia Valentin
  • Negative feedback drives inputs toward equilibrium
    #3 21661833
    Earl Albin
  • Negative feedback sets op-amp gain by resistor ratio
    #4 21661834
    Steve Lawson
  • Negative feedback drives op-amp inputs toward equality
    #5 21661835
    Steve Lawson
  • Output changes gradually, not instantly
    #6 21661836
    Craig Hickman
  • Negative feedback drives inputs equal without ringing
    #7 21661837
    Earl Albin
  • #8 21661838
    Earl Albin
  • Negative feedback drives output to rail limits
    #9 21661839
    Steve Lawson
  • #10 21661840
    Steve Lawson
  • Ringing is a compensation side effect, not fundamental
    #11 21661841
    Earl Albin
  • #12 21661842
    Craig Hickman
  • #13 21661843
    nee Tan
  • #14 21661844
    Steve Lawson
  • Ideal op amp assumptions for circuit analysis
    #15 21661845
    Franklin Rey Pacquiao
Negative feedback stabilizes an operational amplifier (op-amp) by reducing its effective gain from an extremely high open-loop value to a controlled, finite closed-loop gain. An ideal op-amp has infinite gain and input resistance, resulting in negligible voltage difference between its inverting and non-inverting inputs and zero input current. When negative feedback is applied, such as through a voltage divider from output to the inverting input, the output voltage adjusts to minimize the input difference, effectively "driving" the inputs toward equality. This occurs because any voltage difference between inputs is amplified and fed back out of phase, causing the output to correct itself iteratively until the input difference approaches zero. The output does not change instantaneously but builds up gradually, limited by slew rate and supply rails, preventing runaway amplification. While transient ringing can visually illustrate this feedback process, it is a side effect rather than the fundamental mechanism. The key principle is that negative feedback forces the op-amp to settle at an equilibrium where the input terminals have nearly equal voltages, thereby stabilizing the gain and output voltage in accordance with the feedback network.
TL;DR: Negative feedback forces an op-amp’s inputs toward equality by leveraging its huge gain (example: gain ≈1000, slew ≈1 V/µs). As Steve Lawson notes, “Less than infinite gain is a source of error.” [Elektroda, Steve Lawson, post #21661839]
Why it matters: This FAQ helps students and hobbyists understand how feedback makes op-amps stable, predictable, and easy to design.
Why does negative feedback stabilize an op-amp?
The op-amp’s large open-loop gain amplifies any input difference. Negative feedback feeds back an opposing signal, driving that difference toward zero. The output stops changing when the input voltages match within limits, yielding a fixed closed‑loop gain. [Elektroda, Steve Lawson, post #21661834]
What does “the inputs become equal” actually mean?
It means the op-amp drives its output until the inverting input’s voltage equals the non‑inverting input’s voltage. Small residual error remains due to finite gain, but it is tiny in normal operation. [Elektroda, Steve Lawson, post #21661834]
Does the output change instantly when the inputs differ?
No. The output changes as fast as the device allows, limited by slew rate. In the worked example, the slew rate is about 1 V/µs, so the output ramps, not jumps. [Elektroda, Steve Lawson, post #21661839]
How does the resistor ratio set gain (why is it 2 in the example)?
With Rf=2 kΩ and Ri=1 kΩ, the divider forces the inverting input to track the non‑inverting input when the output reaches twice the input magnitude. The closed‑loop gain becomes about 2. [Elektroda, Steve Lawson, post #21661839]
What happens if the op-amp tries to exceed its supply rails?
The output saturates near the rails. In the example with ±15 V supplies, the output only reaches about ±13.5 V. Design so your required swing stays within this limit to avoid distortion. [Elektroda, Steve Lawson, post #21661839]
Why do people say op-amps have “huge gain” and why does that matter?
Huge open-loop gain means even microvolts of input difference create large output moves. Feedback tames that gain into a precise, stable closed‑loop value set by passive parts. “Huge gain” is the foundation of the feedback trick. [Elektroda, Steve Lawson, post #21661834]
Is ringing required for feedback to work?
No. Ringing is a side effect of dynamics and phase margin, not the cause of stabilization. Negative feedback still equalizes inputs when well damped or without visible ringing. [Elektroda, Steve Lawson, post #21661840]
How fast does a non-inverting amplifier settle to its final value?
Settling depends on slew rate and loop dynamics. In the example, the output approaches about 2.0 V over microseconds, limited by 1 V/µs slew and then fine error from finite gain. [Elektroda, Steve Lawson, post #21661839]
Why isn’t the output exactly 2.000 V in the example?
Finite open-loop gain leaves a small error. With gain ≈1000, the closed‑loop output stabilizes slightly below the ideal 2.000 V. “Less than infinite gain is a source of error.” [Elektroda, Steve Lawson, post #21661839]
Do op-amp inputs draw current?
For analysis, assume negligible input currents. That lets you treat the feedback network currents as equal and determine node voltages cleanly. This idealization matches many practical cases. [Elektroda, Steve Lawson, post #21661834]
What if I accidentally apply positive feedback instead?
Positive feedback drives the inputs further apart. The output hunts away from equilibrium and may latch or oscillate. Use correct polarity so the feedback opposes the input difference. [Elektroda, Earl Albin, post #21661833]
How do I analyze a basic inverting amplifier quickly?
  1. Assume input currents ≈ 0 A and inputs at virtual equality.
  2. Write the divider relation at the inverting node using Ri and Rf.
  3. Solve Vout so the inverting node equals the non-inverting reference. [Elektroda, Steve Lawson, post #21661834]
What are the ideal op-amp rules I can safely use on paper?
Use three rules: infinite gain, zero input currents, and zero input voltage difference in closed loop. These simplify designs and predict behavior well. [Elektroda, Franklin Rey Pacquiao, post #21661845]
Can you give a concrete dynamic example with numbers?
Yes. With Ri=1 kΩ, Rf=2 kΩ, gain≈1000, ±15 V supply, and 1 V/µs slew, the output slews toward about 2 V and then fine‑settles. This illustrates practical limits and stabilization. [Elektroda, Steve Lawson, post #21661839]
Are the two inputs ever exactly equal in practice?
No. Noise and finite gain leave a tiny difference. As Earl notes, the inputs never match perfectly, though feedback makes the error very small. [Elektroda, Earl Albin, post #21661838]
What common failure or edge case should I watch for?
Watch for output saturation near rails under large input steps. Once saturated, recovery takes time, and linear behavior resumes only after it leaves the rail. Design headroom to avoid this. [Elektroda, Steve Lawson, post #21661839]
