How Do Inverting and Non-Inverting OpAmp Inputs Affect Output Voltage Calculations?
378 10
How do the inverting and non-inverting op-amp inputs change the way I calculate output voltage in KVL, KCL, or nodal analysis?
The input polarity matters because an op-amp output depends on the difference V+ − V−, so the non-inverting input drives the output in the same direction and the inverting input drives it in the opposite direction [#21665619] In open-loop form, the relation is Vout = A(V1 − V2), where V1 is the non-inverting input and V2 is the inverting input; equivalently, Vout = A(V1 + -V2) [#21665619] In a negative-feedback closed-loop circuit, the op amp drives both inputs toward the same voltage, so a rising voltage on V− makes the output go more negative, while a rising voltage on V+ makes the output go more positive [#21665621] The +/− marking therefore indicates phase relationship and current/voltage polarity, and if the signs are not shown you cannot reliably tell what kind of op-amp circuit it is or analyze it with confidence [#21665621]
  • Inverting and non-inverting inputs determine output polarity
    #1 21665611
    Joseph Sam
  • #2 21665612
    Joseph Sam
  • #3 21665613
    Joseph Sam
  • Inverting input produces opposite output polarity
    #4 21665615
    Steve Lawson
  • Clarifying how op-amp input polarity affects analysis
    #5 21665616
    Joseph Sam
  • Negative feedback forces equal input voltages
    #6 21665617
    Todd Hayden
  • #7 21665618
    Joseph Sam
  • Op amp output equals gain times input difference
    #8 21665619
    Steve Lawson
  • Do op-amp input signs matter in KVL analysis?
    #9 21665620
    Joseph Sam
  • Input signs define op-amp phase relationship
    #10 21665621
    Steve Lawson
  • #11 21665622
    Joseph Sam
The discussion clarifies how the inverting (-) and non-inverting (+) inputs of an operational amplifier (OpAmp) affect output voltage calculations. The inverting input causes the output voltage to be the negative of the input multiplied by the gain, while the non-inverting input results in a positive gain relationship. The fundamental output equation is Vout = A(V+ - V-), where A is the open-loop gain, V+ the non-inverting input voltage, and V- the inverting input voltage. This sign difference is crucial and not merely a convention; it reflects the phase relationship between inputs and output. In closed-loop configurations with negative feedback, the OpAmp forces the input terminals to nearly equal voltages, influencing output polarity accordingly. When analyzing circuits using KVL, KCL, or nodal methods, the input signs must be known to correctly determine the output voltage and phase. Without input polarity information, the problem is unsolvable. The input signs represent the physical behavior of the device, as demonstrated by the internal differential amplifier stage of an OpAmp, where the input polarity controls transistor conduction and thus output voltage polarity. This "forced polarity" concept is essential in understanding and calculating OpAmp behavior in various amplifier configurations.
