How using two or more RF modules at same place is it possible ?
405 8
  • Need separate frequencies or time slots
    #1 21662010
    Ali Hosseiny
  • Need separate RF channels to avoid interference
    #2 21662011
    Mark Harrington
  • #3 21662012
    Mark Harrington
  • Collision detection and time-division multiplexing options
    #4 21662013
    Steve Lawson
  • Time division multiplexing for shared RF link
    #5 21662014
    Mark Harrington
  • Time-division multiplexing options for multiple transmitters
    #6 21662015
    Steve Lawson
  • #7 21662016
    Mark Harrington
  • #8 21662017
    Ali Hosseiny
  • #9 21662018
    Ali Hosseiny
Using multiple FSK 915 MHz transmitter and receiver modules simultaneously in the same location without interference is challenging due to frequency overlap causing data corruption. Since FSK modulation uses two carrier frequencies representing binary symbols, overlapping transmissions on the same frequency band lead to cross-channel interference. To avoid this, different channels or frequency offsets are necessary, similar to how cellular or radio control systems operate by changing crystals or frequencies. Alternative solutions include implementing time division multiplexing (TDM) or time division duplexing (TDD), where transmitters send data in assigned time slots to prevent collisions. Another approach is collision detection with random retransmission delays, inspired by Ethernet protocols. For multiple transmitters in different locations, a master transmitter can synchronize timing for TDM. These methods require additional hardware or protocol design beyond simple StartID and StopID coding. The discussed modules use RS232 at 1200 baud, 8-bit, no parity inverted signaling, and parity testing showed incompatibility. The referenced modules are the HM-R receiver and HM-T transmitter from RoboEQ.
