Gather Data from Multiple Devices in Close Proximity Wirelessly
348 14
How can I wirelessly collect short data messages from up to 200 individually addressable devices within a 50 m radius at minimum cost?
Use a single-frequency low-cost radio scheme with a unique ID in each node and a coordinated transmit schedule so packets do not overlap; the thread suggests cheap 433 MHz modules with a small PIC/EEPROM node, a trigger pulse or timing frame to synchronize transmissions, and a CRC in each packet to detect errors [#21668470] [#21668474] [#21668475] If you want an off-the-shelf option, TI’s MSP430 EZ430-RF2500 kit was recommended as a radio link that worked over more than 50 m line of sight, with the same hardware used for base and remote units [#21668469] The key is to have each device send its ID along with the text and numeric data so the PC can tell which node produced each message [#21668470] [#21668474] A trigger-based “all nodes hear the same mark, then delay by their ID” approach was proposed as a simple way to avoid collisions [#21668470] [#21668475]
  • Low-cost wireless protocol for 200 addressable devices
    #1 21668464
    Enyaw Nitram
  • Clarifying sample rate, timing, and channel coordination
    #2 21668465
    Steve Lawson
  • Raspberry Pi clients sending data to a server
    #3 21668466
    Mark Harrington
  • Clarifying power and size constraints for Pi pods
    #4 21668467
    Steve Lawson
  • Paradox server can accept URL-encoded POST data
    #5 21668468
    Mark Harrington
  • MSP430 EZ430-RF2500 range and site navigation issues
    #6 21668469
    alan Gibson
  • 433 MHz trigger-and-delay scheme for collision avoidance
    #7 21668470
    Enyaw Nitram
  • 433 MHz trigger-and-delay RF scheme proposed
    #8 21668471
    Enyaw Nitram
  • Keyboard-emulation data collection in notepad
    #9 21668472
    Enyaw Nitram
  • #10 21668473
    Enyaw Nitram
  • Zigbee and CRC for multi-device wireless data collection
    #11 21668474
    Mark Harrington
  • Sync transmitters with a timing mark or RTC
    #12 21668475
    Steve Lawson
  • #13 21668476
    Mark Harrington
  • Staggered transmit delays using firmware IDs
    #14 21668477
    Steve Lawson
  • #15 21668478
    Mark Harrington
The discussion focuses on gathering data wirelessly from up to 200 devices within a 50-meter radius, each transmitting a small ASCII text string and two numeric values. The cost target is $15 per module at volume. Key considerations include asynchronous versus scheduled transmission, unique device identification, and legal frequency use in the USA East Coast. Proposed solutions range from low-cost 433 MHz analog RF transmitter modules with unique ID-based time delays to avoid collisions, to more complex IP-based systems using Raspberry Pi devices acting as clients communicating with a server application on a PC. The 433 MHz approach involves each device having a firmware ID that determines a transmission delay after a common trigger pulse, enabling time-division multiplexing without complex coordination. Data integrity may require simple protocols with CRC checks. Alternatives include Zigbee for more reliable two-way communication and TI MSP430 microcontroller-based radio modules, though cost and complexity may exceed the target. Software solutions include server applications handling multiple simultaneous connections, web server POST operations, and polling mechanisms. Power consumption and synchronization methods (e.g., real-time clocks or trigger pulses) are also discussed. Overall, the low-cost 433 MHz transmitter with ID-based staggered transmission is favored for simplicity and cost, while IP-based or Zigbee solutions offer more features at higher complexity and cost.
TL;DR: For up to 200 nearby devices, coordinate transmissions to avoid overlap; one expert notes, "there needs to be a way to coordinate the transmissions." A single frequency with timed slots is workable within 50 meters. [Elektroda, Steve Lawson, post #21668465]
Why it matters:** You’ll cut collisions, meet low-cost targets, and log clean measurements without complex infrastructure.
What wireless approach fits 200 devices within ~50 meters on a budget?
Use a single shared channel with unique time delays per node. Send a common trigger, then each device transmits in its assigned slot. This avoids complex multi-frequency receivers and keeps module cost low. Add simple error checks to handle noise. “There needs to be a way to coordinate the transmissions.” [Elektroda, Steve Lawson, post #21668465]
How do I prevent packet collisions without a complex network stack?
Adopt a trigger-and-stagger scheme. Synchronize all nodes with a trigger mark. Each node waits a unique delay (its ID) before transmitting. Keep messages short and repeat once if needed. This is time-division style coordination on one frequency. [Elektroda, Enyaw Nitram, post #21668470]
Can 433 MHz ‘cheapo’ OOK/FSK modules work for this?
Yes, if you design for noise. Use a long trigger pulse detector, fixed data rate, per-node delay slots, and a CRC at packet end. Expect retries in noisy environments. This balances simplicity with acceptable reliability for weekly, manual reads. [Elektroda, Enyaw Nitram, post #21668471]
Do I need two-way communication or is one-way OK?
One-way can work with staggered slots and CRC, given weekly manual triggers. Two-way adds acknowledgments, retries, and better accuracy, but increases cost and complexity. Consider your error tolerance and maintenance access. [Elektroda, Mark Harrington, post #21668474]
What is TDM in this context?
Time Division Multiplexing assigns each device a unique time slice to transmit. Your firmware-based delays emulate TDM on a single RF channel, reducing overlaps without extra hardware. [Elektroda, Mark Harrington, post #21668474]
How do I synchronize all nodes before they transmit?
Three options: 1) Broadcast a long RF trigger pulse, 2) Power-up sync where all units start together, 3) Preload an internal clock during docking or charging. Choose based on power and service model. [Elektroda, Steve Lawson, post #21668475]
Is Zigbee a better fit than raw 433 MHz modules?
Zigbee provides addressing, retries, and mesh features, easing reliability work but raising cost. For infrequent, small payloads, 433 MHz plus simple protocol may meet goals. “Zigbee could be your answer to some of this.” [Elektroda, Mark Harrington, post #21668474]
What real-world range should I expect indoors?
Line-of-sight exceeded 50 m using TI’s MSP430 RF kit, but range dropped quickly with obstructions. Plan for attenuation through walls and metal. Place the receiver centrally and higher for better coverage. [Elektroda, alan Gibson, post #21668469]
Can I log data straight into Notepad on a PC?
Yes. Use a receiver interface that appears as a keyboard (HID) and prints each device’s tag and two numbers, followed by a newline. Trigger collection, then let nodes transmit in sequence. [Elektroda, Enyaw Nitram, post #21668472]
What’s a simple 3-step way to collect weekly readings?
  1. Send a long RF trigger pulse to all nodes.
  2. Each node waits its unique delay slot, then transmits tag and values.
  3. PC receiver captures lines into a text file and stops after last slot. [Elektroda, Enyaw Nitram, post #21668470]
Should I consider Raspberry Pi or IP-based polling instead?
It works but costs more and needs power. A server can manage many clients, DHCP assignments, and file polling. Great for richer data and continuous logging, but overkill for weekly tiny payloads. [Elektroda, Steve Lawson, post #21668467]
What are CRC and why include it?
A Cyclic Redundancy Check is a short checksum that detects bit errors. Append it to each packet. The PC discards packets with bad CRCs and optionally requests a manual re-trigger later. [Elektroda, Mark Harrington, post #21668474]
Any edge cases I should plan for?
Multipath and obstacles can mute packets, especially beyond rooms or with metal. Schedule a second sweep a few seconds later. Keep slot lengths long enough for worst-case drift since timing is not critical weekly. [Elektroda, alan Gibson, post #21668469]
What about frequency rules and location settings?
Your region affects legal frequencies and power limits. The project is in the USA (east coast), so pick modules accordingly and verify local allowances before deployment. [Elektroda, Enyaw Nitram, post #21668470]
Can I scale beyond 200 devices later?
Yes, extend slot count or add another channel and a second trigger cycle. Keep packets short and fixed-length. If density grows, consider Zigbee or similar to add acknowledgments and retries. [Elektroda, Steve Lawson, post #21668465]
