Power Factor Reading When Only 10KVAR Capacitor Bank Is On, No Motors Running
288 10
What power factor will a power factor meter show when the motors are switched off but the 10 kVAr capacitor bank is still energized on the distribution board?
With the motors off and the capacitor bank still energized, the power factor will be leading and should be close to zero, because the only significant power flow is capacitive VARs [#21662605] If there is essentially no current except small control power, the meter may not give a meaningful steady reading and can sit near the last value or appear random [#21662597][#21662601] If the capacitors are not energized and only small control loads remain, the power factor can be close to 1 [#21662599]
  • Question about PF reading with only capacitor bank on
    #1 21662596
    ASAD ALI
  • Capacitor bank alone gives leading power factor
    #2 21662597
    David Adams
  • #3 21662598
    ASAD ALI
  • #4 21662599
    David Adams
  • #5 21662600
    ASAD ALI
  • Small transformer resistance can raise power factor
    #6 21662601
    David Adams
  • #7 21662602
    ASAD ALI
  • Transformer losses may explain unloaded power factor
    #8 21662603
    David Adams
  • Power factor reading with only capacitor bank energized
    #9 21662604
    ASAD ALI
  • Meter may hold last power factor reading with no load
    #10 21662605
    David Adams
  • #11 21662606
    ASAD ALI
The discussion addresses the power factor reading on a power factor meter when only a 10 kVAR capacitor bank is energized on a distribution board supplying two 10 kW motors, with the motors switched off. The main points clarify that with no motor load, the power factor meter will show a leading power factor due to the capacitive nature of the capacitor bank. Ideally, the real power (kW) is near zero, and the power factor, defined as kW/kVA, can be close to zero or leading, depending on the presence of minor loads such as control transformers. If the power factor meter is located after the main breaker and transformer, the reading reflects the combined effect of transformer losses and capacitor current. In the absence of load current, the meter needle may remain at the last reading or fluctuate randomly. The concept that power factor approaches unity when no current flows is challenged, as zero kW with capacitive current results in a leading power factor less than one. The role of transformer resistance and reactance ratios in influencing unloaded power factor readings is also discussed, emphasizing that small control transformers have higher resistance relative to reactance, which can increase power factor closer to unity under no-load conditions.
