Circuit Diagram Project Ideas for 2nd Year Electronics and Communication Engineering
285 13
What circuit diagram project ideas are suitable for a second-year Electronics and Communication Engineering student?
A good project is to build an FM demodulator using an LM565, paired with an FM modulator that it can decode, such as one built with an LM566 or a Colpitts oscillator VCO. Set the demodulator reference frequency to 10.7 MHz so it matches the standard FM receiver IF frequency [#21663186] If you want the project to stay engaging, pick something that genuinely interests you, because that will make the research, design, and troubleshooting easier to push through [#21663184][#21663196] Another suggestion was to revisit a project you already did in school and improve it for a stronger second version [#21663187]
  • #1 21663183
    Priyanka Gupta
  • #2 21663184
    Steve Lawson
  • #3 21663185
    Steve Lawson
  • FM modulator and LM565 demodulator project suggestion
    #4 21663186
    David Adams
  • #5 21663187
    Floy Viola
  • Encourages student to choose project based on interests
    #6 21663188
    Frank Bushnell
  • Mentoring students to learn engineering thinking
    #7 21663189
    David Adams
  • Suggesting project topics based on student interests
    #8 21663190
    Frank Bushnell
  • Clarifying that help follows initial student effort
    #9 21663191
    Floy Viola
  • #10 21663192
    Frank Bushnell
  • #11 21663193
    Steve Lawson
  • Students need step-by-step lab guidance
    #12 21663194
    David Adams
  • Critique of declining troubleshooting initiative
    #13 21663195
    Steve Lawson
  • Choose a project that is personally interesting
    #14 21663196
    Gregg Williams
A 2nd year Electronics and Communication Engineering student seeks project ideas involving circuit diagrams of electronic systems or devices. Responses emphasize the importance of selecting a project aligned with personal interests and motivations to maintain engagement and facilitate deeper research and design efforts. Suggested project ideas include combining electronics and communication components, such as designing an FM demodulator using the LM565 integrated circuit, paired with an FM modulator based on the LM566 or a voltage-controlled oscillator (VCO) employing a Colpitts oscillator, targeting a 10.7 MHz intermediate frequency typical for FM receivers. Other advice encourages revisiting and improving past successful projects, like a seismograph. The discussion also highlights educational perspectives on student initiative, problem-solving skills, and the evolving need for guidance in engineering education. Additionally, making projects enjoyable and relevant is recommended to reduce stress and enhance learning outcomes.
TL;DR: Best 2nd‑year ECE pick: build an FM modulator + LM565 demodulator at the 10.7 MHz IF standard—“That should keep you busy as a 2nd year student.” [Elektroda, David Adams, post #21663186]
Why it matters: You’ll learn real RF blocks, testing, and troubleshooting while aligning to core communications outcomes—perfect for viva and resumes.
Whats a solid 2nd-year ECE circuit project idea I can actually finish?
Build an FM pair: a simple FM modulator (LM566 or Colpitts VCO) feeding an LM565 FM demodulator. Set the demodulator reference to 10.7 MHz so you can align and verify performance with standard IF test points. “That should keep you busy as a 2nd year student.” [Elektroda, David Adams, post #21663186]
How do I choose a project I wont get bored of?
Pick the topic that gets you up in the morning. Tie the build to your personal interests so you stick with the research, debugging, and iteration. As one mentor put it, let passion guide the topic to avoid burnout in mid‑semester. [Elektroda, Steve Lawson, post #21663184]
Can I combine electronics and communications in one project?
Yes. Pair a small FM modulator you build with your own FM demodulator so the transmitter is your test source. This closes the loop, simplifies demos, and shows system‑level thinking in viva. Set the IF around 10.7 MHz for convenience. [Elektroda, David Adams, post #21663186]
What deliverables make an FM demodulator project look complete?
Include a clear schematic, a block diagram (VCO/modulator → channel → LM565 demodulator), a 10.7 MHz alignment plan, and measured waveforms at input/output. Demonstrate tone recovery and mention limits like capture range. Keep the demo self‑contained with your own modulator. [Elektroda, David Adams, post #21663186]
How do I troubleshoot fast when it doesnt work in lab?
Follow a tight loop: 1. Read the full assignment, including troubleshooting notes. 2. Re‑check wiring with a partner. 3. Verify power is on and rails are correct. Many fails are wiring or power omissions; fix these before deeper dives. [Elektroda, David Adams, post #21663194]
What if I cant source an LM566 for the modulator?
Use a Colpitts oscillator as your VCO. It’s a classic LC topology that pairs well with small‑signal varactor modulation. Keep your carrier near 10.7 MHz so your LM565 demodulator locks reliably during tests. [Elektroda, David Adams, post #21663186]
Is repeating a high‑school project acceptable if I improve it?
Yes. Revisit a past build that gained attention and re‑engineer it. Add better sensing, robustness, or calibration. One contributor redid a seismograph later with stronger execution and upgrades. That approach still earns credit when scoped well. [Elektroda, Floy Viola, post #21663187]
Why do mentors keep saying think for yourself?
Independent thinking raises project quality and grades. Define your interests, set constraints, and take ownership before asking for help. “Start thinking for yourself” is not refusal—it's the push that builds engineering judgment. [Elektroda, Frank Bushnell, post #21663188]
How much guidance should I expect from instructors?
Expect mentoring in how to think, not just circuits. One veteran taught 26 years and saw growing need for structured guidance, yet emphasized developing your own spark and motivation to excel. [Elektroda, David Adams, post #21663189]
What is a Colpitts oscillator?
A Colpitts oscillator is an LC oscillator using a capacitive divider for feedback to set stable RF oscillation. It’s common for VCOs in simple modulators and pairs nicely with varactors for FM. “Colpitts oscillator.” Colpitts oscillator
What is Arduino Nano?
Arduino Nano is a compact development board compatible with Arduino IDE, used for quick prototyping of sensors, displays, and control. It fits breadboards, making it ideal for adding logic or UI around RF builds like an FM demo. “Arduino Nano — Product Page”
What is Tuya?
Tuya is an IoT platform and ecosystem that provides cloud, app, and firmware solutions for smart devices. It enables rapid connected‑product development, though its beyond a basic RF lab scope. “Tuya Smart Platform Overview”
What is OpenBeken?
OpenBeken is open‑source firmware for certain IoT chips, offering local control without vendor clouds. Its useful when repurposing smart plugs or lights in lab projects focused on control electronics. “OpenBeken Documentation”
What is CAN bus?
CAN bus is a robust multi‑master serial bus standard used in vehicles and industry for reliable, priority‑based messaging over twisted pair. Its great for noise‑prone environments but not needed for an FM demo. “CAN in Automation — What is CAN?”
Any edge cases to watch during demo day?
Power and wiring faults derail demos. Instructors often see failures from not reading procedures, skipping troubleshooting steps, or forgetting to power the board. Build a pre‑demo checklist covering power rails, grounds, and signal paths. [Elektroda, David Adams, post #21663194]
Quick 3‑step plan to start my FM project?
  1. Choose LM565 demodulator and set 10.7 MHz reference. 2. Add LM566 or Colpitts VCO as modulator. 3. Verify tone recovery and document waveforms for viva. [Elektroda, David Adams, post #21663186]
