Simple Electronics Project Ideas for University Competition with Circuit Diagrams
300 12
What simple electronics project idea with a circuit diagram can I use for a university competition?
Good starting projects are an RFID-based paid car parking system and a self-switching power supply, both presented with circuit diagrams and explanations [#21667904] For more ideas, search for electronics project ideas lists or keywords like "electronics projects" and "electronics projects ideas" [#21667904] If you choose a project, begin with the function you want to achieve, draw a block diagram, then break it into an architecture and component list [#21667909] After that, check whether the components fit your design and test each block separately before testing the whole circuit [#21667909]
  • #1 21667897
    yasir Noor
  • #3 21667899
    Rodney Green
  • #4 21667900
    Mark Harrington
  • #5 21667901
    yasir Noor
  • Project links for RFID parking and self-switching supply
    #8 21667904
    ElProCus
  • #9 21667905
    yasir Noor
  • Original receiver architectures: Dirodyne and Bedford
    #10 21667906
    Rodney Green
  • #11 21667907
    yasir Noor
  • #12 21667908
    yasir Noor
  • Block diagram first, then component selection and testing
    #13 21667909
    Mark Harrington
An Electrical Engineering student requested simple electronics project ideas with circuit diagrams for a university competition. Responses included links to online resources offering various project ideas and detailed circuit diagrams, such as an RFID-based paid car parking system and a self-switching power supply. Advice emphasized the importance of independently developing project ideas as part of engineering education. One contributor shared advanced concepts involving original radio receiver architectures named "Dirodyne" and "The Bedford Receiver," featuring high dynamic range and innovative audio filtering techniques without DSP. Another user proposed designing an electronic stick for visually impaired persons that detects nearby solid obstacles within a certain range, seeking circuit design assistance. Guidance on project development highlighted starting with system objectives, creating block diagrams, selecting components, and iterative testing of circuit modules to ensure functionality and error correction.
TL;DR: For a student electronics contest, start simple, document everything, and iterate; one contributor “invented independently two new radio receiving architectures” and got “hundreds of emails.” [Elektroda, Rodney Green, post #21667906]
Why it matters: Clear, scoped ideas with diagrams win judges’ time and help beginners ship working builds.
How do I come up with a simple electronics project idea for a competition?
Start from a clear goal, draw a block diagram, choose components per block, then prototype and test each block before integration. Document assumptions and measurements so judges can follow your logic. This structured path keeps scope realistic and shows engineering discipline. [Elektroda, Mark Harrington, post #21667909]
Where can I find circuits with diagrams and explanations?
Use curated idea lists and example builds like an RFID-based paid car parking system or a self‑switching power supply. These posts point to diagrams plus explanations you can study, adapt, and cite. Keep notes on what you change so the work remains yours. [Elektroda, ElProCus, post #21667904]
What is the Dirodyne receiver?
Dirodyne is a high dynamic range radio receiver architecture that still needs additional noise reduction work. It’s presented by a contributor as an uncommon or original approach worth further development for a student project. “Very high DR” makes it attractive for strong‑signal environments. [Elektroda, Rodney Green, post #21667906]
What is the Bedford Receiver?
It’s a radio receiver design using frequency inversion and phase‑shift techniques to achieve variable bandwidth, brick‑wall‑like audio filtering without DSP. The author reports it was recognized as original and widely discussed, making it a solid basis for an updated build. [Elektroda, Rodney Green, post #21667906]
How can I design a smart cane for the blind that detects obstacles?
Define the required detection range (“some meters”), select a distance sensor, and choose an alert method (buzzer or vibration). Keep the form factor cane‑friendly and test in different environments. Log false alarms and missed detections to improve reliability before demo day. [Elektroda, yasir Noor, post #21667907]
Is asking for ready-made circuits acceptable in an engineering degree?
Peers emphasize generating and developing your own ideas. The spirit of the degree is learning to think, design, and validate systems yourself so you become tomorrow’s designer rather than a circuit collector. Do research, then build and explain your choices. [Elektroda, Mark Harrington, post #21667900]
Any quick way to research project circuits online?
Yes: craft targeted searches like “electronic project circuit diagram.” You’ll surface repositories and guides with schematics fast. Use them as references, not final answers, and document any modifications you make for originality and grading credit. [Elektroda, Frank Bushnell, post #21667898]
Can I contact the radio-receiver contributor for more details?
The poster offered to share a soft copy of the Bedford Receiver article and mentioned availability online. A polite outreach referencing the thread and your learning goals can help you obtain resources for study and adaptation. [Elektroda, Rodney Green, post #21667906]
What’s a practical 3-step workflow to go from idea to demo?
  1. Draft a block diagram and list components for each block.
  2. Build and test each block, noting results and issues.
  3. Integrate blocks, retest as a system, and document fixes and performance. This shows judges systematic engineering. [Elektroda, Mark Harrington, post #21667909]
What is RFID in the parking system idea?
RFID uses a reader and passive or active tags to identify vehicles and automate access or payment. In the example shared, you’d design the reader interface, control logic, and actuator drive, then validate reliability and read range for your venue. [Elektroda, ElProCus, post #21667904]
How original were the shared receiver ideas?
The contributor reports the Bedford Receiver was recognized as original and that the articles drew “hundreds of emails” from readers, including translations. That level of interest signals strong learning value and presentation potential for a modern update. [Elektroda, Rodney Green, post #21667906]
Any known pitfalls I should highlight to judges?
Call out limitations proactively. Example: the Dirodyne concept still needs noise reduction, so outline your mitigation plan and test data. Judges reward honest engineering tradeoffs backed by measurements and clear next steps. [Elektroda, Rodney Green, post #21667906]
