Low-Cost Stepper Motor Indexing Circuit for 30° Rotation per Input Signal
282 6
  • Request for a low-cost 30° stepper indexing circuit
    #1 21663476
    Mallikarjun Roogi
  • #2 21663477
    Ian Brown
  • #3 21663478
    Mallikarjun Roogi
  • Microcontroller-driven stepper indexing with microstepping
    #5 21663480
    Jose Quinones
  • #6 21663481
    Doltuku Indonesia
  • #7 21663482
    Steve Lawson
The discussion addresses a low-cost solution for controlling a stepper motor to rotate precisely 30 degrees per input signal, performing an indexing function. The user, with limited electrical knowledge, seeks a simple circuit using basic components. Suggestions include using a microcontroller or FPGA to generate control pulses. A detailed approach involves employing integrated stepper motor drivers such as the DRV8811, DRV8818, DRV8824, or DRV8825, which accept STEP input pulses to control motor position accurately. For a typical 200-step-per-revolution motor (1.8° per step), achieving 30° rotation requires approximately 16.66 steps. Microstepping (e.g., 1/8 step mode) increases resolution to 1600 steps per revolution, allowing precise control by sending 133 microsteps per 30° increment. References to comprehensive stepper motor resources and datasheets are provided for further study.
