Simple Infrared Alarm Circuit Tutorial for Population Counter Project
420 19
How can I build the simplest infrared alarm circuit for a people counter project?
The simplest infrared setup for a people counter is an IR beam-break sensor: place an IR transmitter and receiver across the path, or use one transmitter plus a retroreflector so the beam returns to the source [#21664420][#21664424] For a short range, a narrow-viewing-angle IR LED can work as the emitter, with examples in the 4° to 6° range mentioned in the thread [#21664425] To avoid false triggers and spoofing, modulate the beam and have the receiver check the code pattern instead of responding to steady IR light [#21664423][#21664428] If alignment is a problem, a retroreflector/cataphote is recommended because it removes the need to aim two separate units precisely [#21664424] PIR sensors were also mentioned as an IR option, but the beam-break approach is the more direct fit for counting people passing through a doorway or lane [#21664420]
  • #1 21664419
    George James
  • Explains PIR, beam, and reflector infrared sensors
    #2 21664420
    Steve Lawson
  • #3 21664421
    George James
  • #4 21664422
    George James
  • #5 21664423
    Mark Harrington
  • Retroreflector eliminates infrared alignment issues
    #6 21664424
    Steve Lawson
  • Narrow-beam IR LED part recommendations
    #7 21664425
    Steve Lawson
  • Suggesting RC5 encoding and event logging for IR alarms
    #9 21664427
    Mark Harrington
  • #10 21664428
    Steve Lawson
  • Need encoded beams and dual detectors for vehicle counting
    #11 21664429
    Mark Harrington
  • PIR sensor and pyroelectricity reference links
    #12 21664430
    MOHAN KUMAR
  • #13 21664431
    Steve Lawson
  • #14 21664432
    MOHAN KUMAR
  • #16 21664434
    Steve Lawson
  • Camera-based motion detection as a PIR alternative
    #17 21664435
    Mark Harrington
  • #18 21664436
    Mark Harrington
  • #19 21664437
    Ag Ga
  • #20 21664438
    Steve Lawson
The discussion focuses on designing a simple infrared alarm circuit as part of a population counter project. Three main types of infrared detection methods are highlighted: Passive Infrared (PIR) sensors that detect thermal changes using pyroelectric elements and multi-faceted lenses; infrared laser beams which require modulation and encoding to prevent false triggers; and infrared LEDs with narrow viewing angles for short-range detection. The use of retroreflectors is suggested to simplify beam alignment by reflecting IR light back to the source. Encoding protocols such as the Philips RC5 with Manchester encoding are recommended to differentiate valid signals from spurious IR interference, enhancing reliability. For counting people, a mechanism detecting directional movement within a sliding time window is advised, possibly incorporating multiple detectors and mechanical one-way barriers. Integration with memory chips via I2C for event logging and communication interfaces (Ethernet, serial, WiFi, RF) for remote alerts is proposed for advanced implementations. Alternative technologies like IP or USB cameras with image movement detection software are mentioned as modern replacements for PIR sensors. Several Digi-Key part numbers for narrow-angle IR LEDs are provided as component references. External resources on PIR sensors, pyroelectricity, and thermal imaging are linked for further study. A commercial solution by SensMax offering wireless automatic people counters is briefly noted.
TL;DR: For a people counter, use an IR beam or retroreflective laser; one PIR in the thread even reacted to trucks a mile away—“VERY sensitive.” Build with a modulated beam and decoding to avoid spoofing. [Elektroda, Steve Lawson, post #21664420]
Why it matters: This FAQ helps students and hobbyists choose and build a simple, reliable infrared counter without common false-trigger traps.
What’s the simplest infrared alarm for a population counter?
Use a beam-break setup. Mount an IR emitter across from a receiver, or point a laser at a retroreflector so the return beam hits one receiver. When the beam is interrupted, increment the count. This approach avoids PIR false triggers in changing environments. [Elektroda, Steve Lawson, post #21664420]
How do I stop someone from fooling the IR beam?
Modulate the emitter and decode a known pattern at the receiver. Periodically change or check the code. This blocks a constant-ON jammer or a second emitter placed in front of your sensor. “Include a protocol alongside the beam.” [Elektroda, Mark Harrington, post #21664423]
Do I need a second receiver, or can I use a reflector?
Use a retroreflector to send the beam back to the same unit. It removes most alignment headaches because it returns light toward the source over a wide incident angle range. Ideal where power at the far end is inconvenient. [Elektroda, Steve Lawson, post #21664424]
Can I use an IR LED instead of a laser?
Yes. Narrow-beam IR LEDs with approx. 4–6° viewing angles work well across doorways. They are inexpensive and safer than lasers for indoor builds. Part numbers in the thread show multiple options at low cost. [Elektroda, Steve Lawson, post #21664425]
Is a PIR sensor good for people counting?
PIR detects thermal changes, not explicit crossings. It can false-trigger from distant heat patterns or sun-warmed surfaces cooling in the wind. For precise counts, prefer a beam. “These devices are VERY sensitive.” [Elektroda, Steve Lawson, post #21664420]
How do I count IN vs OUT with beams?
Use two spaced beams and a short time window. If Beam A then Beam B breaks, count IN; the reverse order counts OUT. Add a latch to avoid re-triggers while an object blocks the path. This defeats gate-held-open issues. [Elektroda, Mark Harrington, post #21664429]
Quick build: How do I make a modulated beam counter?
  1. Drive the IR LED with a fixed modulation and known code.
  2. Receive with a photodiode/TSOP, demodulate, and verify the code.
  3. On valid code loss, toggle a microcontroller input and update the count. This resists constant-beam spoofing. [Elektroda, Mark Harrington, post #21664423]
What environmental factors cause false alarms?
PIR can trip from distant traffic heat patterns or sunlit walls cooling in gusts. Beam systems can be held open if the path is intentionally blocked. Shield optics, use modulation, and add timeout logic. [Elektroda, Steve Lawson, post #21664420]
Should I consider webcam or IP-camera motion detection instead of IR?
You can. Image-based motion detection with USB/IP cameras and software (e.g., C#) replaces PIR in some projects and adds rich data. It needs more compute and lighting control. “Now being replaced with image movement detectors.” [Elektroda, Mark Harrington, post #21664435]
Are there off‑the‑shelf people counters I can buy?
Yes. Vendors market wireless people counters and analytics bundles. These save build time but disclose little about internals and may cost more. Evaluate technology, safety, and data access before purchase. [Elektroda, Ag Ga, post #21664437]
Is infrared people counting safe?
IR LED and low-power laser systems are typical; always check emitter class and power. Be cautious with opaque vendors. As one expert noted, unknown tech could even be harmful if misused. Ask for safety documentation. [Elektroda, Steve Lawson, post #21664438]
What modulation or protocol should I use for robustness?
Manchester-encoded schemes like RC5 work well. Add a toggle bit to mark new events, then log timestamps to I2C memory. You can forward events via Ethernet, Wi‑Fi, RF, or SMS for alerts. [Elektroda, Mark Harrington, post #21664427]
What is Arduino Nano?
A compact Arduino board with a microcontroller, USB programming, GPIO, and common serial buses. It fits breadboards and small enclosures, ideal for counters and data loggers. “Arduino Nano — Arduino”
What is Tuya?
A smart‑device platform providing IoT modules, cloud services, and apps for connected products. Many low‑cost sensors and plugs use Tuya ecosystems and chips. “About Tuya — Tuya Smart”
What is OpenBeken?
OpenBeken is community firmware for Beken/Tuya Wi‑Fi MCUs that enables local control and custom logic on IoT devices without cloud reliance. "OpenBeken README — GitHub"
What is CAN bus?
A robust, multi‑master serial network designed by Bosch for vehicles and machinery. It uses differential signaling and message arbitration for reliability in noisy environments. “CAN Specification — Bosch”
