Generating 100V Square Wave AC from High DC Using 555 Timer and Transistor Switch
480 26
How can I switch a 100 V DC supply into a 30–50 kHz, 100 V square-wave output with a 555 timer?
Use the 555 timer only as the gate-drive source and switch the 100 V DC rail with a high-voltage MOSFET stage; the MOSFET should be rated for more than 100 V, preferably around 150% higher, and it only needs enough gate drive to charge its capacitance [#21664545][#21664550] One suggested approach was a complementary pair of transistors: an NMOS to pull the output to 0 V when the 555 output is high, and a PMOS to pull the output up to 100 V when the 555 output is low [#21664545] If the first MOSFET attempt did not work, check the pinout, the drain load resistor, and verify the 555 output with a DC meter at a low test frequency before assuming the switch stage is bad [#21664553][#21664555] The 555 output does not need large current here because MOSFETs are voltage-driven, and the thread notes that a 7.5 V gate drive was enough for the IRFP250N in this application [#21664553] The circuit was eventually confirmed to work with the MOSFET version [#21664560][#21664563]
  • #1 21664539
    JAWED MATEEN
  • #2 21664540
    Cody Tappan
  • #3 21664541
    Floy Viola
  • Use a transistor switch to chop 100 V DC
    #4 21664542
    Omar Hegazy
  • Use a MOSFET switch or H-bridge with a 100 V supply
    #5 21664538
    Omar Hegazy
  • Use a MOSFET inverter instead of voltage doublers
    #6 21664543
    Omar Hegazy
  • Use a MOSFET to switch the 100 V supply
    #7 21664544
    Omar Hegazy
  • PMOS and NMOS push-pull output stage suggested
    #8 21664545
    Cody Tappan
  • #9 21664546
    Syed Shadab
  • #10 21664547
    Omar Hegazy
  • #11 21664548
    Omar Hegazy
  • Transistor sizing for 100V 555 inverter
    #12 21664549
    Cody Tappan
  • #13 21664550
    Steve Lawson
  • 555 output current too low to drive IRFP250N gate
    #14 21664551
    Omar Hegazy
    #15 21664552
    Omar Hegazy
  • Check MOSFET pinout and gate drive with scope
    #16 21664553
    Steve Lawson
  • Measured near-zero AC on transistor drain
    #17 21664554
    Omar Hegazy
  • Drain resistor value and meter frequency may explain zero reading
    #18 21664555
    Steve Lawson
  • #19 21664556
    Omar Hegazy
  • Questioning meter frequency and ammeter hookup
    #20 21664557
    Steve Lawson
  • #21 21664558
    Omar Hegazy
  • Meter limits affect interpreting peak readings
    #22 21664559
    Steve Lawson
  • #23 21664560
    Omar Hegazy
  • #24 21664561
    Steve Lawson
  • #25 21664562
    Steve Lawson
  • #26 21664563
    Omar Hegazy
  • #27 21664564
    Steve Lawson
The discussion focuses on generating a 100V peak square wave AC signal from a high DC voltage source using a 555 timer and transistor switching. The user aims to produce a variable frequency square wave between 30kHz and 50kHz with amplitude from 0 to 100V. The 555 timer output is limited to 7.5V peak and 35mA, insufficient to directly drive the high voltage output. The user experimented with voltage doublers to achieve 100V DC and attempted to switch this with a transistor controlled by the 555 output but faced issues. Suggestions include using a complementary pair of transistors (PMOS and NMOS) to switch the high voltage rail, ensuring the transistors have appropriate voltage ratings (Vce, Vds > 120V) and threshold voltages compatible with the 555 output. The IRFP250N MOSFET was tested but did not work initially, possibly due to incorrect pin connections or measurement errors. It was clarified that MOSFETs are voltage-driven devices requiring minimal gate current, and the 555 output voltage is sufficient to fully switch the transistor. A 1kΩ resistor was used on the drain side. The user confirmed the final solution worked using the MOSFET-based schematic. The discussion also highlights the importance of proper measurement techniques and component selection for high-frequency, high-voltage switching applications.
TL;DR: Build a 100 V square-wave source using a 555 timer to drive a high‑voltage MOSFET; the IRFP250N’s gate threshold is ~4 V, and “MOSFETs are voltage driven devices.” [Elektroda, Steve Lawson, post #21664553] Why it matters: This answers how to switch 100 V DC into a clean 30–50 kHz square wave safely and repeatably for hobby or lab use.
How do I generate a 100 V square wave from 100 V DC with a 555?
Use the 555 as a logic driver and a high‑voltage MOSFET as the switch. Tie the load from +100 V to the MOSFET drain, source to ground, and drive the gate from the 555 through a suitable resistor. Ensure the MOSFET’s Vds rating exceeds the rail. This produces a low‑side switched 100 V square wave at your 555 frequency. [Elektroda, Steve Lawson, post #21664550]
Can a 555 timer safely control a 100 V switch stage?
Yes. The 555 does not see 100 V if it only drives the MOSFET gate. As one expert noted, 100 V is fine because the transistor isolates the timer from high voltage. Keep gate capacitance modest for clean edges. [Elektroda, Cody Tappan, post #21664549]
What MOSFET specs should I pick for 100 V switching at 30–50 kHz?
Select Vds ≥120 V (or higher), suitable threshold (~2–4 V), and low gate capacitances for fast edges. Verify the device can switch at your frequency. The guidance emphasized checking threshold and capacitances to match the 555 output. [Elektroda, Cody Tappan, post #21664549]
Why didn’t my IRFP250N switch when driven by a 555?
Common causes: wrong pinout, ESD damage, or misleading AC measurements. The IRFP250N gate is left, drain center, source right (flat face down, pins toward you). “MOSFETs are voltage driven devices,” so gate current readings near zero are normal. Confirm correct wiring and handling. [Elektroda, Steve Lawson, post #21664553]
How can I test the circuit without an oscilloscope?
Try this quick check:
  1. Short gate to source; measure drain: near 100 V.
  2. Drive gate with ~7.5 V; drain should drop near 0 V.
  3. Run the 555 at ~3 Hz; watch the drain swing on a DC meter. If not, verify 555 swings 0–7.5 V. [Elektroda, Steve Lawson, post #21664555]
My AC meter shows near-zero on the drain. What’s happening?
Many meters read RMS of sine waves and have bandwidth limits. A fast square wave can read wrong or near zero. Measure on DC or slow the frequency to a few hertz for verification, then increase to 30–50 kHz after confirming behavior. [Elektroda, Steve Lawson, post #21664555]
Is a huge 50 A MOSFET overkill if my load current is tiny?
Yes. Oversized parts can still work, but gate charge and leakage may complicate switching. The discussion notes that if the 555 output never reaches true zero, a strong device and low load resistance may prevent full turn‑off. Choose parts sized for your load. [Elektroda, Steve Lawson, post #21664555]
Should I try a bipolar transistor instead of a MOSFET?
A bipolar stage can be more forgiving when learning. The expert provided a simple BJT version as an alternative if the MOSFET path confuses you. Use a proper resistor network and verify with slow-frequency tests first. [Elektroda, Steve Lawson, post #21664553]
Did anyone confirm the MOSFET solution actually works?
Yes. The original poster reported success using the MOSFET schematic and achieved the required switching behavior at the target voltage. [Elektroda, Omar Hegazy, post #21664560]
What about a push‑pull stage (PMOS + NMOS)?
A complementary PMOS/NMOS pair can pull the output actively to both rails. This improves edges and reduces dissipation at higher frequencies. Ensure thresholds suit the 555 drive, and respect device voltage ratings. [Elektroda, Cody Tappan, post #21664545]
How much gate drive current do MOSFETs need from the 555?
MOSFETs mainly need current to charge and discharge the gate capacitance. The thread measured about 35 mA from the 555, which is sufficient for modest capacitances at tens of kilohertz. “MOSFETs are voltage driven devices.” [Elektroda, Steve Lawson, post #21664553]
What resistor value should I put in series with the drain or as a load?
Start with a high value if you only need a logic‑level voltage, not power. Low values increase current and heating. Using too strong a load and a nonzero low gate level can keep the MOSFET partially on. Adjust while monitoring voltage behavior. [Elektroda, Steve Lawson, post #21664555]
What does gate threshold voltage (Vth) actually mean here?
Vth is the gate‑to‑source voltage where the MOSFET just begins to conduct. The IRFP250N example has Vth ~4 V, so a 7.5 V gate strongly turns it on. Ensure your driver exceeds Vth with margin at your switching speed. [Elektroda, Steve Lawson, post #21664553]
Any assembly gotchas like pin orientation or ESD?
Yes. Verify pin order before soldering and use ESD precautions. Miswiring gate, drain, and source or static damage are frequent failure causes. Confirm orientation: gate left, drain center, source right for the referenced package orientation. [Elektroda, Steve Lawson, post #21664553]
