Help designing analog filter designs for an audio activated 8x8x8 LED cube
411 17
How can I design three analog audio filters that amplify a +/-1.5 V MP3-player signal and shift it to a 0-5 V range for a microcontroller ADC without the DC offset breaking the filter behavior?
AC-couple the audio or keep the filters centered around 0 V/virtual ground, then add the DC offset at the output stage so you do not amplify the offset along with the signal [#21665038][#21665042][#21665047] For a single +5 V supply, create a 2.5 V reference and treat that as the circuit’s local ground, so the op-amp inputs and outputs stay within 0 to 5 V [#21665042][#21665045] In Earl’s approach, the resistor ratios are what matter: with R3=R4=R5=R6 the differential section has unity behavior, and the cutoff is set by the R/C network around R3 and C3 rather than by “impedance matching” [#21665042][#21665043] He also notes it is best to set gain before the DC-offset stage, because otherwise the DC offset gets multiplied too [#21665036][#21665043] For the microcontroller input, a rectified and low-pass filtered envelope is usually more useful than the raw audio waveform if the goal is LED visualization [#21665046]
  • Biasing op-amp filters for 0–5V ADC input
    #1 21665033
    Pat Chang
  • Explains DC offset handling with differential amplifiers
    #2 21665034
    Earl Albin
  • Biasing added before low-pass filter caused phase shift
    #3 21665035
    Pat Chang
  • Single-stage filter with pre-offset gain
    #4 21665036
    Earl Albin
  • Suggesting log-scale and Bode plot for filter analysis
    #5 21665037
    Earl Albin
  • Cap-couple the low-pass stage to remove offset
    #6 21665038
    Earl Albin
  • #7 21665039
    Earl Albin
  • #8 21665040
    Earl Albin
  • Questions about gain, cutoff, and single-supply op-amp use
    #9 21665041
    Pat Chang
  • Differential gain and cutoff math explained
    #10 21665042
    Earl Albin
  • Offset polarity reversed in the op-amp stage
    #11 21665043
    Earl Albin
  • Clarifying single-supply op-amp offset workaround
    #12 21665044
    Pat Chang
  • #13 21665045
    Earl Albin
  • Envelope detection before ADC input
    #14 21665046
    Steve Lawson
  • #15 21665047
    Earl Albin
  • #16 21665048
    Earl Albin
  • #17 21665049
    Pat Chang
  • #18 21665050
    Earl Albin
The discussion focuses on designing an analog audio signal processing chain for an 8x8x8 LED cube music visualizer using op amp-based filters. The goal is to convert a ±1.5V audio input from an MP3 player into three separate signals (lowpass, bandpass, highpass) with amplification and DC biasing to produce 0–5V outputs suitable for a microprocessor ADC input. Key challenges include implementing proper DC offset (bias) without a negative power supply, managing phase shifts inherent in filters, and achieving correct gain and cutoff frequencies. Solutions involve using differential amplifiers with level shifting, capacitor coupling to block unwanted DC offsets, and configuring op amps with a virtual ground at half the supply voltage to accommodate single-supply operation. The lowpass filter cutoff is targeted around 500 Hz, with bandpass and highpass filters covering higher frequency bands. Simulation and circuit adjustments were performed in LTSpice, emphasizing resistor and capacitor value selection to set gain and frequency response. The importance of rectification and low-pass filtering for envelope detection was also noted for feeding the microcontroller. The discussion concludes with successful project completion using these analog design principles.
TL;DR: Design your audio‑to‑ADC path with AC coupling, then add a Vcc/2 offset; a first‑order low‑pass rolls off at −20 dB/decade, and “you shouldn’t have 180° inversion unless you use inversion.” [Elektroda, Earl Albin, post #21665037] Why it matters: This keeps your 0–5 V microcontroller ADC safe while maximizing LED‑visualizer resolution for bass, mids, and highs.
How do I bias an audio signal for a 0–5 V ADC on a single supply?
Create a virtual ground at Vcc/2 and reference the filter and differential amp to it. This shifts the waveform into the ADC range without negative swing. Use the virtual ground for signal nodes, not for the op‑amp supply pins. Then add gain as needed. “The (+) of this voltage source behaves like a new ground reference.” [Elektroda, Earl Albin, post #21665042]
Where should the DC offset stage go relative to gain and filtering?
Put gain and filtering before the offset stage. If you add gain after offset, you amplify DC and risk clipping or rail lock. Earl corrected this: the gain block should precede the offset, otherwise it multiplies the DC offset. This ordering preserves headroom and keeps the filter dynamics predictable. [Elektroda, Earl Albin, post #21665040]
Why is my low‑pass output phase‑shifted or inverted?
Low‑pass filters introduce frequency‑dependent phase lag; slope is about −20 dB/decade for one pole. Inversion of 180° only happens if you select an inverting topology or wire it that way. Verify whether you chose inverting or non‑inverting configuration, and check crossover interactions. “You shouldn’t have 180° inversion unless you use inversion.” [Elektroda, Earl Albin, post #21665037]
How do I strip DC offset coming from the audio source?
Use AC coupling: insert a series capacitor at the filter input. It blocks DC and passes audio, simplifying downstream biasing. Earl noted a coupling capacitor is the simpler way to remove source offset before any differential or offset stage. Choose the capacitor with your input resistance to set the high‑pass corner. [Elektroda, Earl Albin, post #21665038]
How do I compute the differential amplifier gain used for offsetting?
With equal resistors, the classic diff‑amp gain is Vout = (V+ − V−)/2. In Earl’s arrangement, the signal feeds one leg, giving effective unity for the signal while setting the DC offset from the other leg. Quote: “The gain of the diff amp... V0 = (V(+) − V(−))/2.” [Elektroda, Earl Albin, post #21665043]
How is the cutoff frequency set in the shown RC leg?
Earl described the time constant as R3 in parallel with R4, with capacitor C3 forming the pole. At low frequency C3 is open, creating a divider; at high frequency C3 shorts the signal. Use τ = Req·C3 where Req = R3 ∥ R4 to set fc = 1/(2πReqC3). He offered to provide the exact equation. [Elektroda, Earl Albin, post #21665042]
Can I avoid a negative supply for the offset source?
Yes. Use the revised connection where the offset source’s negative terminal ties to the same reference as the resistor network. This places the offset on the other leg of the diff‑amp and removes the need for a negative Voffset. It simplifies single‑supply builds using 5 V rails. [Elektroda, Earl Albin, post #21665045]
Should I feed raw audio to the ADC or rectify first?
For LED‑cube envelopes, use band‑pass, then an ideal rectifier, then a low‑pass/gain stage to 0–5 V. That yields amplitude envelopes per band with stable readings. Steve advised rectifying if you want intensity, not full audio content. This approach also provides voltage translation. [Elektroda, Steve Lawson, post #21665046]
How do I split the spectrum into bass, mids, and highs for an LED cube?
Design three paths: LP around 500 Hz for bass, BP near 2.25 kHz for mids, and HP around 4 kHz for highs. Each path gets AC coupling, gain setting, then offset to mid‑supply. Simulate and tune with LTspice before soldering. These targets came from the project brief. [Elektroda, Pat Chang, post #21665033]
What gain do I need from a ~2.85 Vpp source to a 0–5 V ADC?
To span most of 0–5 V, target ≈1.75× overall gain after coupling and filtering. That scales ~2.85 Vpp toward ~5 Vpp, leaving small headroom to avoid clipping at peaks. Confirm with your exact source and op‑amp headroom limits. This figure came from the measured input and requirement. [Elektroda, Pat Chang, post #21665033]
How do I verify the filter response during design?
Run a Bode plot in your simulator and use a logarithmic frequency axis. Inspect both magnitude and phase to confirm the intended crossover and that phase lag matches expectations for your order. Earl suggested log scaling and Bode plots for clearer insight than linear sweeps. [Elektroda, Earl Albin, post #21665037]
What tools or parts were used successfully in this project?
LTspice for simulation, TI FilterPro for initial values, and LT1632 dual op‑amps with 100 nF capacitors and resistors worked. Supply rails available were +5 V and +12 V. The input came from an MP3/iPhone source. This parts and tools list came from the original thread scope. [Elektroda, Pat Chang, post #21665033]
Edge case: My single‑supply LP filter outputs a DC level only—why?
With the negative rail tied to ground and no virtual mid‑supply, the op‑amp cannot swing below 0 V. The stage can bias itself into a DC corner. Add AC coupling and a mid‑supply reference, then re‑bias the stage. Pat observed DC output when trying single‑supply without that reference. [Elektroda, Pat Chang, post #21665041]
What common wiring mistake should I avoid in the filter amplifier?
Do not connect the feedback network to the non‑inverting input by mistake. That miswire breaks the intended transfer function. Earl corrected a schematic where feedback was on the wrong terminal and provided a fixed version with proper gain ordering. Double‑check pin orientations. [Elektroda, Earl Albin, post #21665039]
Quick how‑to: implement a single‑supply biased filter stage
  1. AC‑couple the source into your filter to remove any input DC.
  2. Create a virtual ground at Vcc/2 and reference the signal nodes to it.
  3. After filtering and gain, add the Vcc/2 offset via a diff‑amp and feed the ADC. [Elektroda, Earl Albin, post #21665042]
Did the approach work for the final build?
Yes. The team reported successful completion and graduation after implementing the advised changes. They thanked Earl for the assistance. This confirms the practical viability of AC coupling, correct gain ordering, and proper offsetting in a real LED‑cube project. [Elektroda, Pat Chang, post #21665049]
