How to Store and Change User Password in ATtiny2313 for Code-Based Switch Project
360 9
Where can I store a user-changeable password in an ATtiny2313-based code switch project?
Store the password in the ATtiny2313's internal EEPROM if it must be changed by the user and kept after power-off; external EEPROM is the other option if you need more space [#21665327] For a simple setup, use an LCD and a 4x3 keypad so the user can enter and change a 4-character password [#21665328] Save the password as byte/array data in EEPROM, then read it back and compare it when the user enters the code [#21665327][#21665330] The advice was also to start by writing a small C program that takes keypad input into an array and stores four chosen values before moving on [#21665330] The thread suggests learning arrays, keypad handling, and EEPROM basics first, and not worrying about AVR Studio until those are clear [#21665332][#21665334]
  • #1 21665326
    Gireesh Kumar
  • Suggesting EEPROM-based password storage and user interface design
    #2 21665327
    Mark Harrington
  • #3 21665328
    Gireesh Kumar
  • #4 21665329
    Mark Harrington
  • Start with array input and output exercise
    #5 21665330
    Mark Harrington
  • #6 21665331
    Gireesh Kumar
  • Learn PC and JavaScript basics before ATtiny2313 coding
    #7 21665332
    Mark Harrington
  • #8 21665333
    Gireesh Kumar
  • #9 21665334
    Mark Harrington
  • #10 21665335
    Mark Harrington
The discussion focuses on implementing a user-changeable password system on an ATtiny2313 microcontroller for a code-based switch project. Key considerations include selecting an appropriate display output such as LEDs or an LCD, determining password length and character set (numeric or alphanumeric), and managing password storage. Storage options discussed are internal EEPROM of the ATtiny2313 or external EEPROM modules, with attention to memory size and communication protocols. The importance of learning fundamental programming concepts such as arrays, keypad input handling, and basic C programming is emphasized before progressing to microcontroller-specific development. Suggested development environments include free C compilers compatible with NetBeans IDE, Oracle tools, or Code::Blocks, with a recommendation to first practice on PC applications or simple JavaScript/HTML exercises. The discussion discourages providing direct code solutions to encourage foundational understanding. The user plans to use a 4x3 keypad, a 4-character password, an LCD display, and internal EEPROM for storage.
