How to Design a Keyboard Editable Running Message Signboard for Embedded Projects?
651 54
How can I design a keyboard-editable running message signboard for an embedded project?
Use the ready-made PIC-based scrolling text project shared in the thread; it includes the schematic, firmware sources, compiled HEX, manual, and a Proteus project, and it is controlled through RS-232C (COM port) for scrolling text [#21665486][#21665507] If you need English text, the key step is to redraw the character sprites from the original Russian set into Latin characters; the author says the display can show any characters once the sprites are replaced [#21665478][#21665498] The same source package was later updated as an English/Latin version, with the note that the keyboard input should match standard PS/2 key codes [#21665524][#21665525] So the practical path is: take the existing circuit and code, adapt the font tables/sprites for Latin, and use the provided serial interface/protocol rather than starting from scratch [#21665486][#21665507]
  • #1 21665475
    Muazu Musa
  • #2 21665476
    Eugene Lisovy
  • #3 21665477
    Muazu Musa
  • #4 21665478
    Eugene Lisovy
  • #5 21665479
    Eugene Lisovy
  • Requesting display interface details and hardware photos
    #6 21665480
    Mark Harrington
  • #7 21665481
    Muazu Musa
  • #8 21665482
    Muazu Musa
  • #9 21665483
    Mark Harrington
  • #10 21665484
    Muazu Musa
  • #11 21665485
    Mark Harrington
  • #12 21665486
    Eugene Lisovy
  • Requesting Proteus tests of several oscillator circuits
    #13 21665487
    Mark Harrington
  • #14 21665488
    Muazu Musa
  • Clarifying PC write, delete, and restore steps
    #15 21665489
    Muazu Musa
  • Clarifying project scope, memory, and interface needs
    #16 21665490
    Mark Harrington
  • Requesting feedback on hardware, PCB, and R&D costs
    #17 21665491
    Mark Harrington
  • #18 21665492
    Muazu Musa
  • #19 21665493
    Muazu Musa
  • Serial EEPROM needed for editable message storage
    #20 21665494
    Mark Harrington
  • Shift direction question for scrolling text display
    #21 21665495
    Mark Harrington
  • 5x7 LED matrix PCB gerbers for sale or DIY
    #22 21665496
    Mark Harrington
  • #23 21665497
    Muazu Musa
  • #24 21665498
    Eugene Lisovy
  • Clarifying shift-register flow and missing interface details
    #25 21665499
    Mark Harrington
  • Requests complete C/ASM program and hex files
    #26 21665500
    Muazu Musa
  • RS232 level mismatch risks PIC and PC ports
    #27 21665501
    Mark Harrington
  • #28 21665502
    Eugene Lisovy
  • Advocates independent checks before importing electronics
    #29 21665503
    Mark Harrington
  • #30 21665504
    Mark Harrington
The discussion centers on designing a keyboard-editable running message signboard for embedded projects, focusing on hardware and software integration. The original poster seeks a complete solution including circuit schematics and source code to build a signboard capable of displaying scrolling text editable via a keyboard interface. Contributors provide resources such as schematic diagrams, Proteus simulation files, and firmware source codes primarily in assembly and C languages. The design involves using microcontrollers interfaced with LED matrix displays, typically 8x8 or 10x8 dot matrix modules, controlled via shift registers like the 74HCT595 and line decoders (3-to-8 line decoder). Communication protocols discussed include RS-232 serial interface and PS/2 keyboard interface. Key challenges addressed include character sprite mapping for Latin alphabets, memory expansion for storing multiple messages, and voltage regulation for powering LED arrays. Suggestions include modular design approaches, reprogramming shift registers with microcontrollers to replace discrete components, and ensuring proper RS-232 voltage level conversion to protect microcontroller inputs. The discussion also touches on PCB design considerations, component sourcing, and software front-end development for message input and management. Participants emphasize understanding communication protocols (SPI, serial), microcontroller programming (assembly, C, Proton BASIC), and hardware interfacing to achieve a functional, editable running message display.
TL;DR: RS‑232 swings can be −3 V to −25 V for logic 1 and +3 V to +25 V for logic 0; “don’t plug the hardware into your PC as yet.” [Elektroda, Mark Harrington, post #21665501]
Why it matters: This FAQ helps beginners build a keyboard‑editable running message signboard safely, from interface to power and fonts, using PIC/LED matrices.
How do I safely connect a PC to the sign over RS‑232?
Use a MAX232 (or similar) between the PC’s RS‑232 and the PIC’s TTL UART. Wire TX, RX, GND; set baud and framing in firmware. Avoid direct connection because RS‑232 can apply ±10–25 V and damage the PIC and even your PC port. As one expert warned, “don’t plug the hardware into your PC as yet.” [Elektroda, Mark Harrington, post #21665501]
Can this project be edited with a standard PS/2 keyboard and show English text?
Yes. The PS/2 variant accepts key presses and displays Latin characters after updating the font sprites and firmware. The author delivered a version that “will now be displayed in Latin characters” when you type on a standard PS/2 keyboard. [Elektroda, Eugene Lisovy, post #21665518]
What’s the difference between the RS‑232 and EEPROM builds?
The RS‑232 build streams text from a PC over a COM port. The EEPROM build stores messages on the sign and plays them without a PC. English firmware was supplied for the RS‑232 version, and a prior package covered the EEPROM variant. [Elektroda, Eugene Lisovy, post #21665524]
How do I start sending text from my PC and later delete or replace it?
For RS‑232, create a small front‑end that opens the COM port and sends ASCII strings. Add simple commands for clear, write, and start. For EEPROM, your firmware should implement erase/write routines for message slots and a play loop. A member confirmed RS‑232 control and provided sources. [Elektroda, Eugene Lisovy, post #21665486]
What font or sprite work is needed to get full A–Z support?
Redraw the character sprites from the original Cyrillic set to Latin A–Z (and a–z if needed). Replace the glyph tables in the source, then recompile. The author shared an example and offered to “redo all the sprites for Latin characters.” [Elektroda, Eugene Lisovy, post #21665498]
I’m missing letters like J, G, U, or W—how do I fix that?
Update the sprite table to include every ISO basic Latin glyph you need. Verify the PS/2 scancode map points to the correct glyph indices. Rebuild HEX and flash. The contributor later posted English‑ready sources and manual to resolve missing letters. [Elektroda, Eugene Lisovy, post #21665507]
What regulator should I use for a multi‑module LED sign?
A 7805 can run hot or current‑limit around 1 A with large matrices. Use an LM338 or a high‑current regulator. Set the adjust network with 120 Ω and size wiring for current. Heatsink the regulator and test under worst‑case brightness. [Elektroda, Eugene Lisovy, post #21665528]
How big is a typical character font, and why does it matter for memory?
A common 5×7 font needs 35 bits per character (≈5 bytes with padding). At 96 printable characters, allocate ≈480 bytes for glyphs, plus spacing. Larger fonts or extra symbols scale linearly. One member discussed 5×7 matrix modules for display output planning. [Elektroda, Mark Harrington, post #21665496]
What’s a quick 3‑step to get scrolling text working?
  1. Flash the provided English RS‑232 HEX to the PIC. 2. Add a MAX232 and connect COM‑port TX/RX/GND. 3. Send your string from a terminal/front‑end; the firmware scrolls it. [Elektroda, Eugene Lisovy, post #21665486]
What’s the safe RS‑232 voltage range and the main failure to avoid?
RS‑232 defines logic 1 as −3 V to −25 V and logic 0 as +3 V to +25 V. Feeding these directly into a PIC’s TTL pins risks permanent damage to both the microcontroller and the PC port. Always insert a level shifter. [Elektroda, Mark Harrington, post #21665501]
How do I handle Proteus project files that won’t open on my version?
Use the same or newer Proteus version as the shared design, or request a saved‑as‑older export. When a user on v7.0 couldn’t open a file, they asked for a compatible Proteus project or guidance. [Elektroda, Muazu Musa, post #21665493]
How are columns and rows driven on 8×8 or 5×7 modules?
The design shifts bytes through 74HC595 registers, latches columns, and selects rows via a 3‑to‑8 decoder. Firmware clocks out sprite rows and multiplexes quickly to avoid flicker. A contributor analyzed this approach and its latching sequence. [Elektroda, Mark Harrington, post #21665499]
What memory strategy should I use for multiple stored messages?
Add I²C EEPROM to hold messages and iterate them in a loop. The mentor advised upgrading the processor and adding memory if you want the sign to run independently after disconnecting a laptop. [Elektroda, Mark Harrington, post #21665490]
What is CAN bus?
CAN bus is a robust multi‑drop serial network for controllers and sensors, designed for reliability and error handling in noisy environments. It is often considered for scalable signage or industrial links. [Elektroda, Mark Harrington, post #21665508]
What is Arduino Nano?
Arduino Nano is a small breadboard‑friendly development board based on an 8‑bit AVR MCU, often used for quick LED matrix prototypes and serial bridges. “Use what gets you building fast.” [Arduino Nano — Official Docs]
What should I know about baud rate selection here?
Choose a baud rate the PIC can handle with your clock, then match it in your terminal. Start conservative to validate the link, then raise if refresh and buffer allow. A mentor explicitly raised baud‑rate planning as a key step. [Elektroda, Mark Harrington, post #21665501]
