PWM Circuit Design for Regenerative Braking on 36V Mobility Scooter With 4 Motors
255 6
  • Needs a separate regenerative braking circuit for 36 V scooter motors
    #1 21665881
    Jeffrey Pardus
  • #2 21665882
    Mark Harrington
  • #3 21665883
    Peter Evenhuis
  • Purpose of diode across drain and supply
    #4 21665884
    Jeffrey Pardus
  • Question about diode purpose and boosting low brake voltage back to batteries
    #5 21665885
    Jeffrey Pardus
  • #6 21665886
    Shrikant Kamble
  • MOSFET body diode already provides flyback protection
    #7 21665887
    Mark Harrington
The discussion focuses on designing a PWM circuit for regenerative braking on a 36V mobility scooter equipped with up to four high-current motors (38A each). The user aims to implement a system where reducing power via a 5K potentiometer initiates regenerative braking to slow the scooter, with automatic braking at minimum power and smooth acceleration when power increases. The control circuit operates at 12V PWM to drive MOSFET banks handling the 36V battery pack (42-43V peak). Direction control is managed by relays due to limitations with P-channel MOSFETs in H-bridge configurations. Suggested braking methods include dynamic braking by shorting motor terminals to generate reverse voltage, dissipating energy in high-power resistors, or using a full-wave bridge rectifier to feed energy back into the battery via a voltage doubler and PWM control. The PWM frequency is recommended around 16 kHz to reduce audible noise, with capacitors across diodes for tuning. The regenerative braking circuit employs a full-wave bridge allowing braking in both forward and reverse directions, controlled by relays for forward, reverse, and braking states. Questions remain about the purpose of diodes placed across MOSFET drain and supply terminals. The conversation also touches on the practical challenges of implementing regenerative braking and the importance of schematic diagrams for clarity.
