Can I add an additional stage of mosfets to increase current capacity of a speed controller? Whatwou
360 6
  • Need to drive the original mosfet gate signals
    #1 21681390
    Shepherd Ginzburg
  • Increase current by beefing up output transistors and sense resistor
    #2 21681391
    David Ashton
  • Add MOSFET drivers and new shunt resistor
    #3 21681392
    Rick Curl
  • #4 21681393
    Shepherd Ginzburg
  • #5 21681394
    Shepherd Ginzburg
  • #6 21681395
    Cologne LED
  • #7 21681396
    Rick Curl
The discussion addresses the feasibility of increasing the current capacity of a brushless motor speed controller for electric bicycles by adding an additional stage of MOSFETs. It is confirmed that this can be done, but not simply as an external add-on box. Instead, the original output stage must be disabled, and the control signals driving the original MOSFET gates should be used to drive a new circuit board with larger MOSFETs. Key modifications include removing existing gate resistors (1kΩ and 470Ω) and inserting dedicated MOSFET driver ICs, such as the Microchip MCP14E4, which are non-inverting dual-channel drivers. The upper MOSFETs in the new stage must be P-channel, and the lower ones N-channel, with 10kΩ pull-down resistors on driver inputs to prevent shoot-through by ensuring complementary switching. Additionally, the current sensing resistor value should be adjusted (e.g., from 50 mΩ to 10 mΩ) to accommodate higher current limits, as the original comparator-based current limit circuit triggers at about 2A with the original resistor. The MC33035 controller IC is noted for its bipolar push-pull transistor outputs capable of sourcing/sinking 25-50 mA, suitable for moderate power levels typical in bicycle motors. Overall, the approach involves integrating larger MOSFETs driven by proper gate drivers and adjusting current sensing to safely increase power output.
