Best Sensors for Accurate Car Detection in Real Car Time Lap Racing Project
420 14
What sensor should I use to detect a real car crossing a finish line from about 1–2 meters away so I can stop a lap timer accurately?
A modulated IR or laser “electric eye” across the track is the best choice for accurate lap detection [#21667246][#21667259] Use either a sender/receiver pair on opposite sides of the track, or put both on the same side and use a retroreflector on the far side so the beam is reflected back [#21667246] Modulating the beam makes it less vulnerable to stray light [#21667246] RFID can identify which car passed, but the detection distance may vary and that can make the timing point inconsistent [#21667259] An induction coil/metal detector can also work, but only if the car reliably passes directly over the coil for repeatable results [#21667259]
  • Recommend beam-break sensors for 1–2 m car detection
    #1 21667245
    ali Aburamya
  • Retroreflective beam sensor for finish-line detection
    #2 21667246
    Steve Lawson
  • Alternative car detection methods suggested
    #3 21667247
    Steve Lawson
  • Barcode readers suggested for unique car identification
    #4 21667248
    Mark Harrington
  • #5 21667249
    Mark Harrington
  • #6 21667250
    Steve Lawson
  • Railway-style trigger and ID logging approach
    #7 21667251
    Mark Harrington
  • #8 21667252
    Steve Lawson
  • #9 21667253
    Steve Lawson
  • #10 21667254
    Steve Lawson
  • Rail track circuits detect cars by axle shorting
    #11 21667255
    Steve Lawson
  • Questioning reflector use in long-range IR sensing
    #12 21667256
    ali Aburamya
  • #13 21667257
    ali Aburamya
  • #14 21667258
    Steve Lawson
  • Laser beam offers more repeatable finish-line detection
    #15 21667259
    Steve Lawson
The discussion focuses on selecting precise sensors for detecting car movement in a real-time lap racing project involving two cars on a single track with separate start lines. Suggested sensor types include infrared or visible light "electric eye" beam systems with either opposite-side sender and receiver or same-side sender/receiver with a retroreflector to reduce stray light interference. Pneumatic switches, metal detectors (inductive coils), video cameras with motion detection, and RFID systems are also considered. RFID offers unique car identification but typically has short range (e.g., RDM630 with 5-10 cm range), raising concerns about detection consistency and timing precision. Bar code readers were proposed but questioned for speed capability. Railway track circuit analogies were discussed, where steel wheels complete an electrical circuit for detection, but this is not applicable to typical car wheels. The consensus leans toward a laser or modulated IR beam across the track as the most reliable method for precise timing, with metal detectors as a secondary option if cars pass consistently over coils. Reflectors improve beam reliability, but car body reflections may cause false signals. Overall, the best solution balances detection accuracy, timing precision, and practical installation constraints.
TL;DR: For accurate, repeatable lap timing, use a modulated IR/laser break‑beam with a retroreflector; it supports 2 basic beam arrangements and "If you modulate the beam it becomes less vulnerable to stray light." [Elektroda, Steve Lawson, post #21667246]
Why it matters: This FAQ helps race‑timing builders choose the right sensor for reliable, to‑the‑millisecond car detection on real tracks.
Quick-Facts:
What’s the best sensor to detect a real car crossing the finish line?
Use a modulated laser/IR break‑beam aimed at a retroreflector. It gives a crisp, repeatable crossing point and resists ambient light. As one expert put it, “a laser beam across the track is the best bet.” Place optics outside the impact zone for safety. [Elektroda, Steve Lawson, post #21667259]
How do I cut false triggers from sunlight or headlights on a break‑beam?
Modulate the light source and match the receiver to that frequency. This filters steady ambient light and reduces false trips. A same‑side sender/receiver with a retroreflector also simplifies wiring and alignment across a lane. “If you modulate the beam it becomes less vulnerable to stray light.” [Elektroda, Steve Lawson, post #21667246]
Will car reflections mess with a one‑sided sensor?
Yes. A passing car can reflect the beam back to the receiver and mimic a valid return. Plan baffles, adjust angle, or favor an opposite‑side break‑beam to ensure the car reliably breaks, not completes, the beam. This is a known edge case for reflective setups. [Elektroda, Steve Lawson, post #21667258]
Can RFID time laps and identify each car reliably?
LF readers like the RDM630 usually read at about 5–10 cm. That’s too short for a wide lane and high‑speed cars unless antennas are very close. It identifies vehicles, but range limits make precise finish‑line timing difficult without tight geometry. [Elektroda, ali Aburamya, post #21667257]
Are there long‑range RFID kits for this, and what’s the catch?
Development kits exist, but the read point varies with tag orientation and distance. That variability introduces timing error at the finish line. Use RFID for ID if needed, and a separate break‑beam for the exact timing edge. [Elektroda, Steve Lawson, post #21667259]
Would a barcode reader work on full‑size cars at speed?
It’s risky. A contributor questioned whether a barcode could be read fast enough as a car speeds by. Motion blur, angle, and distance reduce read reliability. Favor RFID for ID or avoid codes for the timing edge. [Elektroda, Steve Lawson, post #21667250]
What is a retroreflector, and why use it here?
A retroreflector sends light back to its source over a wide angle. With sender and receiver on one side, it completes the beam path without running wires across the track. This setup is common and simplifies installation. [Elektroda, Steve Lawson, post #21667246]
How does an inductive loop (“metal detector”) finish‑line sensor work?
A buried coil senses metal mass overhead. It can trigger consistently, but only if the car passes directly over the coil each time. Mis‑tracking reduces repeatability, so lane discipline is essential for accurate timing. [Elektroda, Steve Lawson, post #21667259]
Could a pneumatic hose switch serve as a lap trigger?
Yes. A closed‑end rubber tube connected to a pressure switch can sense axle loads, much like old full‑service gas station bell hoses. It’s simple, but placement and wear affect long‑term accuracy. [Elektroda, Steve Lawson, post #21667247]
Can I use a camera with motion detection instead of beam sensors?
You can, as seen in security systems, but ambient lighting changes and processing latency can add jitter. For sub‑frame precision, pair video for review with a beam sensor for the exact timing edge. [Elektroda, Steve Lawson, post #21667247]
What detection range should I design for on this project?
Design for straight‑line sensing over approximately 1–2 meters, per the original requirements. A retroreflective laser/IR break‑beam suits that span and keeps the trigger point narrow for precise stop events. [Elektroda, ali Aburamya, post #21667245]
How do I build a reliable finish‑line break‑beam (quick start)?
  1. Mount a laser/IR emitter and matched receiver on one side; place a retroreflector directly across the lane.
  2. Drive the emitter with a modulation signal; add a receiver filter tuned to that frequency.
  3. Align for maximum signal, then set a threshold that trips only when the beam is physically blocked. [Elektroda, Steve Lawson, post #21667246]
How can I tell which of two cars crossed first?
Use a unique ID method at each start/finish, such as RFID per car, to tag events. Alternatively, place separate beam sensors at the two staggered start lines and log triggers independently. RFID also helps distinguish cars, if range allows. [Elektroda, Steve Lawson, post #21667247]
