Effect of Increasing Governor Setting on 100-kVA Generator Supplying 40kW Load
327 6
  • #1 21667286
    ASAD ALI
  • #2 21667287
    Steve Spence
  • #3 21667288
    ASAD ALI
  • #4 21667289
    Chuck Sydlo
  • #5 21667290
    Steve Spence
  • #6 21667291
    Chuck Sydlo
  • Governor changes frequency, not regulated voltage
    #7 21667292
    David Adams
A 100-kVA generator supplying a 40 kW load operates with a governor designed to maintain engine rpm and thus stabilize AC frequency under varying load conditions. Increasing the governor setting while the load remains constant causes the engine speed to rise, resulting in an increase in output frequency. This frequency change can adversely affect connected AC loads, especially motors not equipped with variable frequency drives (VFDs), which will accelerate to a new speed. Voltage is typically regulated independently by a voltage regulator; if present and functioning correctly, voltage remains stable despite speed changes. Without voltage regulation, voltage will increase proportionally with speed. To increase power output without altering frequency, adjustments to fuel and air supply are made separately from governor rpm settings. The governor’s primary function is to maintain a set rpm against load variations, ensuring frequency stability.
