24C04 I2C EEPROM read issue after several words with 89C52 microcontroller assembly
417 6
  • #1 21667426
    Debdas Choudhury
  • #2 21667427
    Boi Okken
  • Need processor, flowchart, and character map details
    #3 21667428
    Mark Harrington
  • #4 21667429
    Debdas Choudhury
  • #5 21667430
    ganesh Bhosle
  • #6 21667431
    Debdas Choudhury
  • #7 21667432
    Debdas Choudhury
An assembly language program was developed for an Atmel 89C52 microcontroller to save and read words from a 24C04 I2C EEPROM using data from a PS2 keyboard. The writing process to the EEPROM functions correctly, but during reading, after successfully retrieving several words, the system hangs. The PS2 keyboard input is processed by counting scan codes on each clock pulse. The issue was suspected to be related to stack overflow or insufficient RAM. After reinitializing the stack pointer with the instruction MOV SP,#5FH, the hanging problem was resolved, indicating that proper stack management is critical when interfacing the 89C52 with the 24C04 EEPROM and PS2 keyboard in assembly.
