8051 Microcontroller Embedded C Code for 1-Hour ON/OFF Relay Cycle and Relay Interfacing
459 7
  • #2 21667889
    Pradeep Ravi
  • Clarifying crystal, timing source, and relay specs
    #3 21667891
    stephen Van Buskirk
  • #4 21667892
    Amri Fauzan
  • 555 unsuitable for accurate timing; use crystal or AC pulse counting
    #5 21667893
    stephen Van Buskirk
  • MikroC 8051 relay cycle code with 1-hour delays
    #6 21667894
    Syed Shadab
  • #7 21667895
    Mark Harrington
The discussion focuses on developing an embedded C program for the 8051 microcontroller to control a relay with a 1-hour ON and 1-hour OFF cycle. Key considerations include the microcontroller's crystal frequency, power supply specifications, relay coil voltage and current, and the need for accurate timing. A sample MikroC code snippet demonstrates toggling Port 1 pins to drive the relay with 1-hour delays using delay_ms(3600000). Relay interfacing recommendations include using a transistor driver, optocoupler for isolation, and a 5.1V Zener diode for overvoltage protection. Alternative timing methods such as a 555 timer are mentioned but noted as less accurate compared to crystal-based timing. Additional resources for timing and LCD display integration are referenced.
