How to Keep LED On for 1 Hour with Switch Activation—Simple Timer Circuit Ideas
624 14
How can I make a battery-powered LED turn on with a switch and stay lit for about 1 hour in a very small enclosure?
Use a small 8-pin microcontroller or a dedicated timer IC rather than a capacitor-only delay; an RC/transistor circuit won’t reliably run for an hour in your size and battery constraints [#21680137][#21680138] A cheap Microchip/PICAXE-style 8-pin MCU can handle the 1-hour timing in software with just one decoupling capacitor plus the LED and its resistor, and you may add a regulator if you need constant brightness [#21680135][#21680138] If you want a non-programming solution, TI’s TPL5111 is an easy timer that covers 100 ms to 7200 s, and it can drive a transistor stage if the LED current is higher than the chip can supply [#21680130] Another IC-only option mentioned is a CD4541 or a modified CD4060 timer circuit for long delays [#21680139][#21680142][#21680140] A plain 555 was also mentioned, but for a true one-hour delay it would need very large timing values and leakage could make it unreliable [#21680138][#21680129]
  • #1 21680128
    Jason Lukacsko
  • Clarify power source and timing accuracy requirements
    #2 21680129
    David Ashton
  • TPL5111 suggested for 1-hour LED timer
    #3 21680130
    Rick Curl
  • Compact battery timer for 1-hour LED illumination
    #4 21680131
    Jason Lukacsko
  • #5 21680132
    Jason Lukacsko
  • Clarifying requirements and suggesting timer relays
    #6 21680133
    Aubrey Kagan
  • Clarifying switch type, timing, and accuracy requirements
    #7 21680134
    Max Maxfield
  • 8-pin microcontroller timer with regulator for constant LED brightness
    #8 21680135
    Aubrey Kagan
  • #9 21680136
    Justin Spencer Mamaradlo
  • Hour-long LED timing needs a much larger capacitor
    #10 21680137
    Elizabeth Simon
  • PICAXE 08M2 suggested for reliable 1-hour delay
    #11 21680138
    David Ashton
  • #13 21680140
    David Ashton
  • #14 21680141
    Jason Lukacsko
  • #15 21680142
    Richard Gabric
The discussion addresses how to keep an LED illuminated for one hour after activation by a switch, focusing on a compact, battery-operated design with a 2.5" diameter and 0.5" height constraint. Various timing approaches are considered, including analog and digital solutions. The 555 timer IC is suggested for simple timing but lacks precision and requires large resistor and capacitor values for hour-long delays, which may be impractical due to size and leakage issues. Counting mains power cycles is mentioned but not applicable for battery operation. Digital microcontrollers, such as low-pin-count Microchip PIC or PICAXE microcontrollers, offer precise timing with minimal components and programmability, suitable for the size and power constraints. Timer ICs like the Texas Instruments TPL5111 system timer and CMOS counters such as CD4060 and CD4541 are proposed as alternatives for adjustable delays without complex programming. Mechanical relay timers are noted as simple but inaccurate. The importance of clarifying switch type (toggle or momentary), retriggerability, and timing accuracy is emphasized. Battery voltage and LED current requirements influence component selection, with suggestions to use transistor interfaces for higher LED brightness and voltage regulators for consistent illumination. Overall, microcontroller-based timing is favored for accuracy and compactness, while analog and relay solutions are less practical for a precise one-hour LED activation in a small, battery-powered device.
TL;DR: For a one‑hour LED timer in a small, battery‑powered build, use TI’s TPL5111 ("generate delays between 100 milliseconds and 7200 seconds") or a tiny 8‑pin micro; 555 RC is imprecise for 1 hour. [Elektroda, Rick, post #21680130]
Why it matters: This FAQ helps makers pick a reliable, compact 60‑minute LED‑on solution without trial‑and‑error.
What’s the simplest way to keep an LED on for about 1 hour?
Use a low‑power timer IC or an 8‑pin microcontroller. TPL5111 covers up to 7200 s on 1.8–5 V. Add a small NPN transistor if the LED needs more current than the timer pin can source. This approach fits tight spaces and keeps time well enough for a product claim. A pure RC fade is not practical for 60 minutes in your size. [Elektroda, Rick, post #21680130]
Will a single big capacitor keep an LED on for an hour?
Not realistically here. At 3 V supply and ~10 mA LED current, a rough calculation shows about 72 farads for a 0.5 V drop. That’s a supercapacitor class part and won’t fit a 0.5‑inch‑tall puck with other electronics. It also won’t hold constant brightness. [Elektroda, Anonymous, post #21680137]
Can a 555 timer do a precise 1‑hour delay?
It can, but not precisely or reliably in this use. Achieving ~3600 s needs ~22 MΩ and up to 1000 µF. Capacitor leakage and tolerance drift make the result erratic. As one expert notes, the 555 is “not very precisely” suited for long delays. [Elektroda, Anonymous, post #21680138]
What is the TPL5111 system timer and why use it?
TPL5111 is a low‑power system timer IC from TI that generates programmable delays from 100 ms to 7200 s on 1.8–5 V. It’s easy to use and ideal for battery builds. Use a transistor interface if your LED requires higher current or constant brightness. [Elektroda, Rick, post #21680130]
How do I build a 1‑hour LED timer with TPL5111?
  1. Power the TPL5111 from your battery (1.8–5 V) and set its delay for 3600 s.
  2. Drive a small NPN transistor from the TPL5111 output; size the LED resistor for your brightness.
  3. Wire the user switch to start the cycle and route LED power through the transistor. [Elektroda, Rick, post #21680130]
What about using a tiny 8‑pin microcontroller?
An 8‑pin Microchip PIC can time one hour using its internal oscillator and simple code. You add one decoupling cap, the LED, and a resistor. Consider a regulator if you want constant LED brightness as the battery sags. This keeps parts count and size very low. [Elektroda, Anonymous, post #21680135]
What is PICAXE, and can it do this easily?
PICAXE is a beginner‑friendly microcontroller platform programmed in BASIC. The 08M2 8‑pin device can time 1 hour and drive an LED with minimal parts. It’s cheap, easy to program, and suitable for quick proof‑of‑concept builds and small enclosures. [Elektroda, Anonymous, post #21680138]
Are CD4060 or CD4541 better for 1‑hour timing?
Yes, both are long‑delay timer/counter ICs. CD4060 provides an oscillator with divider stages, while CD4541 is a programmable timer. With the right RC and wiring, they can deliver a one‑shot around 1 hour in a compact board. “Nice call… doable.” [Elektroda, Anonymous, post #21680139]
I need battery power and a small enclosure; what should I watch?
Choose low‑power timing and avoid large RC values. The enclosure is about 2.5 inches in diameter and 0.5 inches tall. That rules out supercaps and bulky relays. Favor TPL5111 or an 8‑pin micro, plus a small transistor for LED drive. [Elektroda, Anonymous, post #21680131]
Do I need a transistor to drive a bright LED?
Often yes. Timer outputs source limited current. Use a single NPN transistor to switch the LED current set by a resistor. This keeps the timer happy and maintains brightness over the hour. It also preserves timing accuracy by reducing output loading. [Elektroda, Rick, post #21680130]
Should the timer retrigger if the switch is toggled again?
Decide behavior up front. Define whether a second toggle restarts the 1‑hour count or is ignored. Engineers recommend clarifying switch type, start conditions, and retrigger logic before choosing parts or code. This avoids surprises in user tests. [Elektroda, Anonymous, post #21680134]
Toggle vs. push‑button: when should the hour start?
Specify this in your design. With a toggle, start timing when turned ON, or when turned OFF after arming. With a push‑button, start at press or release. Document these rules so your circuit or code implements the correct user experience. [Elektroda, Anonymous, post #21680134]
Can I use mains frequency to keep one hour very accurate?
Yes, counting 50/60 Hz cycles gives accurate timing. However, this project is battery‑powered and space‑limited, so mains is impractical here. Keep this option in mind for mains‑powered products that demand tighter accuracy without crystals. [Elektroda, Anonymous, post #21680129]
Is a spring‑return mechanical timer switch viable?
It works for rough timing, but it’s bulky and inaccurate for a 0.5‑inch‑tall puck. Mechanical options suit low‑precision tasks. For product‑grade one‑hour timing, prefer IC‑based solutions with defined tolerances and compact footprints. [Elektroda, Anonymous, post #21680136]
Any gotchas that can break a 1‑hour design?
Watch electrolytic leakage and tolerance in large RC networks. They drift and shorten or lengthen the delay. Battery droop also dims LEDs unless you regulate or PWM. As one poster put it, large‑value 555 timing can become “erratic or unusable.” [Elektroda, Anonymous, post #21680138]
