Best IC for Anti-Lost Alarm Receiver to Pair With NE555 Transmitter?
360 9
What receiver IC or circuit should I use for a simple anti-lost alarm that needs to detect a signal from a transmitter, and is an NE555 a good choice for the transmitter?
Use a stable, purpose-built RF receiver approach rather than trying to pair an NE555 transmitter with an arbitrary receiver; the thread says a 555 is too unstable for reliable frequency matching and may cause the receiver to need an overly wide range [#21668324] A better suggestion is to use SAW-filter/resonator circuits like those used in remote-control key fobs and RF doorbells, since they are used in both transmitters and receivers for this kind of task [#21668325] Another option mentioned is small radio-control IC pairs such as Tx-2B/Rx-2B [#21668326] If you want to stay with a simple discrete approach, a ceramic resonator with an op amp was suggested as more stable than a 555, and searching for a “carrier detector” receiver circuit was recommended [#21668324]
  • Request for receiver IC to pair with NE555 transmitter
    #1 21668322
    Jun Tung Loh
  • #2 21668323
    Steve Lawson
  • Suggesting a ceramic resonator and op amp receiver
    #3 21668324
    stephen Van Buskirk
  • Suggesting SAW filters for receiver selectivity
    #4 21668325
    Mark Harrington
  • #6 21668327
    Jun Tung Loh
  • #7 21668328
    Jun Tung Loh
  • #8 21668329
    Mark Harrington
  • #9 21668330
    Jun Tung Loh
The discussion centers on selecting an appropriate integrated circuit (IC) for the receiver in an anti-lost alarm system designed to track pets or children. The transmitter uses an NE555 timer IC to generate oscillations, but the receiver IC choice is uncertain. Responses highlight that the NE555 may lack frequency stability and accuracy, potentially causing receiver issues such as false triggers. Alternatives suggested include using a dual 121 IC like the L4LS221, ceramic resonators combined with operational amplifiers for improved frequency stability, or employing SAW (Surface Acoustic Wave) filters commonly used in RF remote controls and automotive electronics for precise signal filtering. Additional recommendations include simple Hartley oscillators, CMOS logic oscillators using ICs like the 4069, and RF modules such as Rx-2B and Tx-2B used in small radio-controlled devices. Links to application notes and datasheets from Freescale and Epcos provide further technical guidance on SAW components and resonators. The overall advice cautions beginners about the complexity and reliability requirements of such projects involving safety-critical applications.
