Best Simulation Software for GSM 900/1800 MHz RF Detector Circuit Design
258 12
How can I simulate a 900 MHz or 1800 MHz GSM RF signal in software for testing a cell phone detector circuit?
Use a simulated sinewave source set to 900 MHz or 1800 MHz, and adjust its amplitude to microvolts and its impedance to match the antenna or circuit input [#21668801] If you need a frequency source outside the simulator, a PLL and VCO can be used to generate the required frequency, or a Marconi signal generator can serve as a test instrument [#21668803] Another practical suggestion was to build and test the detector directly with correctly valued components and a good antenna, rather than relying only on simulation [#21668805]
  • Proteus cannot generate 900/1800 MHz RF signals
    #1 21668800
    EEWeb
  • Use a simulated sine source at 900/1800 MHz
    #2 21668801
    Steve Lawson
  • #3 21668802
    EEWeb
  • #4 21668803
    Jimmy Babida
  • Suggesting cheaper alternatives to expensive RF test gear
    #5 21668804
    Mark Harrington
  • #6 21668805
    NIHKIL GUNDAGE
  • #7 21668806
    EEWeb
  • #8 21668807
    NIHKIL GUNDAGE
  • #9 21668808
    Mark Harrington
  • #11 21668810
    Mark Harrington
  • #12 21668811
    EEWeb
  • #13 21668812
    EEWeb
The discussion addresses the challenge of simulating GSM 900/1800 MHz RF signals for a cell phone detection circuit design. Proteus was found inadequate for generating these high-frequency RF signals directly. Suggestions include using a simulated sine wave source at 900/1800 MHz with appropriate amplitude and impedance settings to mimic antenna input. Incorporating a Phase Locked Loop (PLL) and Voltage Controlled Oscillator (VCO) is recommended for frequency generation when using microcontroller prescalers. Practical alternatives involve using hardware signal generators such as the Marconi or Slumberger test instruments, though these are costly (around £3000-£4000). Cheaper, hands-on approaches include building tuned circuits responsive to the target frequencies combined with microcontrollers (e.g., PIC microcontrollers) with ADC and serial output for detection and readout. Several DIY field strength meter designs and resources were shared to facilitate low-cost implementation. Emphasis was placed on direct component testing, correct component selection, and antenna design for effective signal reception and detection.
TL;DR: For GSM 900/1800 MHz detector design, simulate with a sinewave source, microvolt-level input, and 50 Ω match; full RF generators can cost ~£6,000. “Use a simulated sinewave source.” [Elektroda, Steve Lawson, post #21668801]
Why it matters: This FAQ helps students and RF hobbyists choose practical tools and workflows to test GSM detectors before building hardware.
What’s the simplest way to simulate a GSM 900/1800 MHz RF signal?
Place a sinewave source at 900 or 1800 MHz in your simulator. Set amplitude in microvolts and match source impedance to your antenna or LNA input. Drive your detector’s input with this source. As one expert put it, “use a simulated sinewave source.” This approach validates gain, filtering, and detection thresholds before buying RF gear. [Elektroda, Steve Lawson, post #21668801]
Can Proteus generate a 900/1800 MHz test signal for my circuit?
Yes, by adding an AC source configured to 900 or 1800 MHz and choosing a realistic small-signal amplitude. Ensure the source and input impedances match to reduce reflections in the model. This mimics an RF generator closely enough for detector bring-up in simulation. [Elektroda, Steve Lawson, post #21668801]
What if my design uses a prescaler or divided clock—how do I still reach 900/1800 MHz?
Add a PLL with a VCO. The PLL multiplies your reference, while the VCO tunes to the GSM bands. This combination overcomes division losses and locks the target frequency. Mismatch here is a common failure case; the loop must cover your desired channels. [Elektroda, Jimmy Babida, post #21668803]
How much does lab-grade RF generation for GSM testing cost?
Expect about £3,000 for a Marconi or Schlumberger signal generator. Some setups need an additional messaging adaptor around £3,000. That’s roughly £6,000 before other accessories, so plan budgets accordingly. [Elektroda, Mark Harrington, post #21668804]
What’s a lower-cost path without high-end RF gear?
Build a tuned RF front end covering roughly 900–1200 MHz and use a PIC microcontroller with an ADC for measurements. Output to a PC or LCD for live readouts. This path trades money for learning and can validate detection thresholds effectively. [Elektroda, Mark Harrington, post #21668808]
Do you have example resources for a DIY field-strength meter?
Yes—community references include step-by-step notes and schematics you can adapt for GSM-band checks. These help you verify relative field strength during bench tests and antenna tweaks without pricey instruments. [Elektroda, Mark Harrington, post #21668809]
What is a PLL and why do GSM detectors care?
A Phase-Locked Loop (PLL) locks an oscillator to a reference, multiplying or dividing to reach target RF. Pair it with a VCO to synthesize 900/1800 MHz test carriers or local oscillators. It’s essential when clock dividers alone miss the band. [Elektroda, Jimmy Babida, post #21668803]
What is a VCO?
A Voltage-Controlled Oscillator changes frequency with a control voltage. In GSM test setups it tunes across the cellular bands under a PLL’s control. Correct tuning range and stability determine whether your detector sees realistic signals. [Elektroda, Jimmy Babida, post #21668803]
How can I read detector output without a full RF lab?
Route the detector’s envelope or RSSI to a PIC microcontroller ADC. Stream values over UART to a PC or display on an LCD. This gives rapid feedback when sweeping frequency or adjusting the antenna. [Elektroda, Mark Harrington, post #21668808]
Is there a quick three-step way to validate my design in simulation first?
  1. Insert a sine source at 900 or 1800 MHz with microvolt-level amplitude. 2. Match impedances at the source and detector input. 3. Sweep amplitude and log the detector output threshold. [Elektroda, Steve Lawson, post #21668801]
I’m on a tight budget—should I buy a generator or prototype first?
Prototype first. Build the tuned front end and use microcontroller-based readouts and DIY field-strength tools. Only move to pricey generators if your design needs calibrated absolute levels for certification or advanced demodulation. [Elektroda, Mark Harrington, post #21668804]
Any gotchas when covering both 900 and 1800 MHz?
Broadband front ends can lose selectivity. A single tuned circuit from 900–1200 MHz won’t fully span 1800 MHz. Use switched tanks or dual paths, or rely on a PLL/VCO source to evaluate each band separately. [Elektroda, Mark Harrington, post #21668808]
Should I test on breadboard or PCB at these frequencies?
Expect instability with casual wiring. Keep leads short, ground well, and enclose sensitive sections. If a prescaler divides too far, your detector may miss-target; verify with a synthesized source. [Elektroda, Jimmy Babida, post #21668803]
Can I validate results without absolute-calibrated power levels?
Yes. Use a DIY field-strength meter to compare relative changes while you tune filters and antennas. Once behavior is consistent, consider renting lab gear for calibration. This staged approach saves thousands. [Elektroda, Mark Harrington, post #21668809]
What brands or tools were suggested in the discussion?
Marconi and Schlumberger RF generators were noted for lab-grade work. For budget builds, a PIC micro with ADC plus simple tuned circuits and field-strength references were highlighted. [Elektroda, Mark Harrington, post #21668804]
