Do you use the parametric filters on electrical component sites?
342 10
Do engineers actually use parametric search filters on electronic component distributor sites, and which ones work best?
Yes—many users rely on parametric filters, especially on Mouser and Digi-Key, and one user says they use Digi-Key’s search filter almost every day [#21668730] [#21668732] [#21668739] Mouser and Digi-Key are described as working well, while Allied’s filters “leave a bit to be desired” [#21668730] A recurring issue is inconsistent manufacturer naming for the same part, such as 250mw/0.25W/1/4W, 0.1uF/100nf, and multiple switch-state labels, which makes filtering harder because you have to account for all the variants [#21668732]
  • #1 21668729
    Nate Hull
  • #2 21668730
    Steve Spence
  • Build your own supplier database and filters
    #3 21668731
    Mark Harrington
  • Inconsistent part naming breaks parametric filters
    #4 21668732
    Steve Lawson
  • #5 21668733
    Steve Lawson
  • Scraping supplier websites to build a parts database
    #6 21668734
    Mark Harrington
  • Barcode-based component naming to avoid data entry errors
    #7 21668735
    Mark Harrington
  • #8 21668736
    Steve Lawson
    #9 21668737
    jianglu Lu
  • #10 21668738
    Steve Lawson
  • #11 21668739
    DAVID CUTHBERT
Parametric filters on electronic component distributor websites such as Arrow, Mouser, Digi-Key, Newark, and Allied are used by many professionals to streamline component selection. Mouser and Digi-Key filters are generally regarded as effective, while Allied's filters are less satisfactory. A common challenge is inconsistent manufacturer specifications and naming conventions (e.g., power ratings like 250mW/0.25W/1/4W or switch types with varied notations), complicating filter accuracy. Some users prefer creating personalized databases and custom filters to track components, suppliers, pricing, lead times, and supplier reliability, rather than relying solely on supplier websites. Suggestions include automating data extraction from supplier webpages and implementing a universal barcode system for components to standardize identification and reduce manual data entry errors. Despite the usefulness of parametric filters, many emphasize that supplier reliability, price, and delivery are more critical factors than the sophistication of online filtering tools.
