Best way to detect voltage from DIY radio antenna for beginner radio projects
297 25
How can I detect the tiny voltage from a DIY radio antenna for a beginner radio project?
Use a receiver or RF detector made for the frequency you want to work with, not a regular voltmeter; at 5.8 GHz you will usually need a receiver capable of that band, and an RSSI output or built-in S-meter if the receiver provides one [#21683921][#21683922][#21683937][#21683942] If the signal is strong enough, a small-signal Schottky diode detector followed by a low-frequency amplifier can detect the carrier, but these detectors are simple and not very linear [#21683921][#21683934] For a practical beginner setup, buy a prebuilt receiver or demo board with the amplifier already built in, then connect your antenna to it and measure the receiver output level [#21683942] A spectrum analyzer is the most direct test instrument, but it is expensive; an oscilloscope at 5.8 GHz is also impractical for most beginners [#21683921][#21683922] The thread also suggests starting at a lower frequency such as 2.4 GHz or even with a crystal set kit to learn the basics before attempting 5.8 GHz [#21683919][#21683922][#21683934]
  • #1 21683917
    david lopez
  • Need frequency range and signal details
    #2 21683918
    Richard Gabric
  • #3 21683919
    David Ashton
  • #4 21683920
    david lopez
  • Need frequency and modulation details
    #5 21683921
    Richard Gabric
  • Use a receiver and amplifier for 5.8 GHz signals
    #6 21683922
    Elizabeth Simon
  • #7 21683923
    david lopez
  • 50 ohm standard for transmitter matching
    #8 21683924
    Elizabeth Simon
  • Antenna voltage is only a few microvolts
    #9 21683925
    Giovanni Di Maria
  • #10 21683926
    david lopez
  • Impedance differs from DC resistance in antennas
    #11 21683927
    Elizabeth Simon
  • #12 21683928
    david lopez
  • Explaining antenna impedance and reactance
    #13 21683929
    PeterTraneus Anderson
  • #14 21683930
    david lopez
  • Antenna impedance is rarely exactly 50 ohms
    #15 21683931
    Richard Gabric
  • #16 21683932
    Elizabeth Simon
  • #17 21683933
    david lopez
  • Schottky and RF detector options for 5.8 GHz
    #18 21683934
    Richard Gabric
  • #19 21683935
    Giovanni Di Maria
  • #20 21683936
    david lopez
  • #21 21683937
    Elizabeth Simon
  • #22 21683938
    david lopez
  • RSSI output likely drives the S-meter
    #23 21683939
    Elizabeth Simon
  • #24 21683940
    david lopez
  • Recommend starting with lower-frequency RF basics
    #25 21683941
    Richard Gabric
  • Recommend using a receiver with built-in amplifier
    #26 21683942
    Elizabeth Simon
Detecting voltage from a DIY radio antenna, especially at 5.8 GHz, presents significant challenges due to very low signal levels typically in the microvolt range and the complexity of high-frequency RF design. Simple detection methods like crystal sets or diode detectors (e.g., Schottky diodes) can work at lower frequencies but require sufficient signal strength and often amplification. Measuring voltage directly at 5.8 GHz with instruments like oscilloscopes is impractical and expensive. Instead, using a dedicated radio receiver or transceiver chip with built-in demodulation and an RSSI (Received Signal Strength Indicator) output is recommended for signal detection and measurement. S-meters, commonly integrated into receivers, provide signal strength readings but are frequency-specific and require a compatible receiver for 5.8 GHz. Antenna impedance is frequency-dependent and rarely exactly 50 ohms; 50 ohms is a standard impedance for coaxial cables and RF systems to optimize power transfer. Antenna design and impedance matching are critical, with software tools like MMana-Gal or EZNEC useful for simulation. Beginners are advised to start with lower frequency projects to build foundational RF knowledge before tackling 5.8 GHz systems. Commercial evaluation boards and low-cost receivers (e.g., from SparkFun) can facilitate experimentation. Regulatory compliance is important when transmitting signals.
TL;DR: Typical receive voltages are in the microvolt range; 1000× gain turns 12 µV into 12 mV. For 5.8 GHz you need "gain, and a lot of it." [Elektroda, Anonymous, post #21683918]
Why it matters: Beginners asking “how do I detect voltage from a DIY 5.8 GHz antenna?” get a practical path—tools, terms, and safer starting points—without expensive lab gear.
What’s the best beginner-friendly way to detect voltage from a 5.8 GHz antenna?
Use a prebuilt 5.8 GHz receiver module and read its RSSI or S‑meter output. Direct voltage at the antenna is tiny and hard to measure. A receiver gives gain, filtering, and a calibrated indicator. Start at lower frequencies if you can, then move to 5.8 GHz once comfortable. [Elektroda, Anonymous, post #21683922]
Can I just use an oscilloscope directly on the antenna?
Not recommended. Antenna signals are only microvolts and the scope input loads the antenna, reducing level further. Without a very high‑frequency scope and a low‑noise front end, you will not see meaningful results. “Connecting the oscilloscope you will lower this signal.” [Elektroda, Anonymous, post #21683925]
Will an S‑meter work at 5.8 GHz?
Yes, if the S‑meter is part of a receiver that tunes 5.8 GHz. Standalone S‑meters aren’t used at RF inputs. In many radios, the S‑meter derives from the receiver’s RSSI path, so choose a receiver covering your band. [Elektroda, Anonymous, post #21683937]
What is RSSI, and why is it useful here?
RSSI is Received Signal Strength Indicator. It outputs a voltage or digital value proportional to input signal level in dB. Many RF transceivers expose RSSI for easy strength readings without lab gear. “Most chips have a thing called an RSSI output.” [Elektroda, Anonymous, post #21683921]
How do I amplify microvolts to something measurable?
Detect with an RF Schottky diode or RF detector, then amplify the baseband (low‑frequency) output. A small‑signal Schottky on the antenna followed by a low‑frequency amplifier can detect a strong carrier. For better linearity, use an integrated RF detector IC. [Elektroda, Anonymous, post #21683921]
Is an antenna always 50 ohms?
No. Antenna impedance varies with frequency, geometry, and environment. Designers aim near 50 Ω to match common coax and gear, but exact 50 Ω is rare. You can add a matching network if needed. [Elektroda, Anonymous, post #21683932]
Why is 50 Ω a thing in RF?
It’s a historical and practical coax standard balancing power handling and loss. Using 50 Ω simplifies matching across transmitters, cables, and test equipment. TV receive systems often use 75 Ω instead. [“Why Fifty Ohms”]
How does antenna impedance change with frequency?
Impedance is complex (R + jX) and shifts with frequency. A half‑wave dipole is about 72 Ω resistive at resonance; move off frequency and reactance appears. Designers target resonance for minimal reactance. [Elektroda, Anonymous, post #21683929]
How can I measure or estimate my antenna impedance without expensive gear?
Model it first using antenna software such as MMANA‑GAL or EZNEC. Simulation predicts impedance near your frequency, guiding dimensions and matching. Then iterate build‑and‑test as needed. [Elektroda, Anonymous, post #21683925]
What’s a simple detector I can build for 5.8 GHz?
A Schottky diode envelope detector can work with strong signals, followed by DC amplification. At 5.8 GHz, layout and parts choice matter. For more linear readings, consider an Analog Devices RF power detector on a demo board. [Elektroda, Anonymous, post #21683934]
Is starting at 5.8 GHz a bad idea for beginners?
It’s challenging due to tiny signals, tight tolerances, and costly test gear. Many learners begin at lower bands (e.g., 2.4 GHz) where modules, tools, and examples are abundant, then step up. [Elektroda, Anonymous, post #21683941]
What off‑the‑shelf gear can help me experiment quickly?
Buy a ready 5.8 GHz receiver or an SDR platform with coverage and RSSI/S‑meter. SparkFun and Lime Microsystems boards are common starting points. Ensure the module supports your band and outputs level data. [Elektroda, Anonymous, post #21683922]
Can I use an S‑meter without a matching 50 Ω antenna?
Yes, within reason. Receivers are tolerant when receiving, but a poor mismatch reduces captured power and accuracy. Add a simple matching network if SWR is high to improve readings and repeatability. [Elektroda, Anonymous, post #21683932]
What’s the risk if I try to transmit during tests?
Unauthorized transmissions can violate regulations and incur penalties. Verify the permitted bands, power, and modulation for your country before transmitting. Use dummy loads and receivers during development. [Elektroda, Anonymous, post #21683922]
How does gain translate to usable voltages?
With 1000× overall gain, 12 µV at the antenna becomes about 12 mV at the detector output. That level is easy to measure with a DMM or microcontroller ADC. Keep stages stable to avoid oscillations. [Elektroda, Anonymous, post #21683925]
How do I quickly get a signal level reading from my DIY antenna?
Try this 3‑step path:
  1. Connect your antenna to a 5.8 GHz receiver module with RSSI/S‑meter.
  2. Tune to the target frequency and note the RSSI/S‑meter value.
  3. Compare readings as you adjust antenna length or matching. [Elektroda, Anonymous, post #21683939]
