Inrush limiting circuit for 50W Flyback SMPS using MOSFET suggestions
273 7
  • #1 21669260
    Sankalp Gitaje
  • Suggesting relay-bypassed primary resistor for inrush control
    #2 21669261
    Rohit Dubla
  • #3 21669262
    DAVID CUTHBERT
  • #4 21669263
    aswin Vallamkondu
  • #5 21669264
    Sankalp Gitaje
  • #6 21669265
    Sankalp Gitaje
  • NTC resistor recommended for inrush limiting
    #7 21669266
    DAVID CUTHBERT
  • Step-start resistor with MOSFET bypass for inrush limiting
    #8 21669267
    DAVID CUTHBERT
The discussion addresses inrush current limiting methods for a 50W flyback SMPS using MOSFETs. Key points include the typical use of NTC thermistors in series with the input to limit initial current by their high resistance at ambient temperature, which decreases as they heat up during operation. Another approach involves a step-start resistor in series with the input capacitor, which is bypassed by a MOSFET after the capacitor charges, effectively reducing inrush current. Soft-start features on switcher ICs can also limit inrush by controlling the power-up ramp time, particularly by adjusting the soft-start capacitor. The inrush current problem is often related to the bulk input capacitor charging. Practical examples mention a universal input voltage with 24V output, where inrush was reduced from 20A to 8A using these methods. Compliance with standards such as EN60950 is necessary when implementing step-start circuits on the DC side of rectifiers to protect against line transients. A specific NTC resistor example given is the EPCOS B57235S0100MO. The use of a TOPSwitch IC from Power Integrations with an NTC was noted, but additional soft-start or step-start circuitry may be required for further inrush reduction.
