W9NK90Z MOSFET Switching High Current with 2nF Cap and 4.418uH Air Core Inductor
381 14
How can I make a W9NK90Z MOSFET switch more current in my resonant Tesla coil circuit without exceeding its 30 V gate-source limit?
You should not try to use 30 V on the gate; 10–12 V is enough to turn the W9NK90Z on hard, and 15 V is about as high as MOSFETs are normally driven [#21669975][#21669977] The low current you are seeing is more likely a modeling/load issue than a gate-voltage issue, because the transformer secondary needs a resistive load to reflect power into the primary; otherwise the circuit is mostly just the primary magnetizing inductance and resonance energy exchange [#21669981][#21669984] David Cuthbert said that with a load impedance below about 15 ohms the MOSFET should switch more than the 6.59 A you simulated, so the missing current points to the circuit model rather than the device [#21669984] He also recommended building the simulation in smaller steps and, if needed, replacing the MOSFET temporarily with a square-wave source to verify the transformer model first [#21669984] After doing that with LTSpice and a similar MOSFET, the drain current ramped as expected, which further suggested that your simulator’s MOSFET model was the problem [#21669988]
  • MOSFET gate drive limited by 30 V VGS breakdown
    #1 21669974
    Cody Gass
  • #2 21669975
    DAVID CUTHBERT
  • Gate voltage chosen to minimize MOSFET on-resistance
    #3 21669976
    Cody Gass
  • #4 21669977
    DAVID CUTHBERT
  • Gate voltage reduction would lower MOSFET current
    #5 21669978
    Cody Gass
  • #6 21669979
    DAVID CUTHBERT
  • Clarifying the load and Tesla coil circuit context
    #7 21669980
    Cody Gass
  • Need a resistive secondary load for primary power transfer
    #8 21669981
    DAVID CUTHBERT
  • #9 21669982
    Paul Sr
  • Gate-source voltage limits MOSFET current drive
    #10 21669983
    Cody Gass
  • Add a resistive secondary load to reflect primary impedance
    #11 21669984
    DAVID CUTHBERT
  • MOSFET saturation current limited by gate voltage, not load
    #12 21669985
    Cody Gass
  • Simulation disagrees with datasheet current curves
    #13 21669986
    Cody Gass
  • Airlab MOSFET suited for high-current AEGs
    #14 21669987
    John Steave
  • #15 21669988
    DAVID CUTHBERT
The discussion centers on using the W9NK90Z MOSFET with a 30V gate-source breakdown voltage to switch high current in a circuit comprising a 2nF capacitor and a 4.418µH air core inductor forming the primary of a Tesla coil transformer. The MOSFET source is grounded, and the drain connects to the capacitor-inductor parallel network, driven by a voltage source sufficient to saturate the MOSFET. The user employs a 30V gate drive to maximize current, despite typical gate voltages being around 10-15V for full saturation. Simulation challenges arise due to lack of a SPICE model for the W9NK90Z, leading to discrepancies in predicted current (around 6.6-6.9A) versus datasheet expectations (up to 18A at 10V gate drive). The circuit includes resistors to bleed voltage and models transformer parameters with estimated inductances and coupling coefficient (~0.2). It is noted that the load on the secondary must be resistive to reflect proper load to the primary and enable realistic current flow. Suggestions include using LTSpice with a similar MOSFET model (STW11NM80) for more accurate simulation. The discussion also touches on Tesla coil design considerations such as coupling coefficient, primary inductance, and resonant tuning. The user plans to integrate a MIDI-interrupted dual resonant solid state Tesla coil with variable frequency and duty cycle control. Additional remarks mention MOSFETs designed for high current switching in applications like upgraded AEGs, highlighting the importance of device selection for power handling and reliability.
TL;DR: For the W9NK90Z, Rds(on) ≈ 1.1 Ω and “10 volts [gate] is enough to turn this device on hard.” Drive gates 10–15 V, not 30 V. Fix load modeling and use LTspice to validate V = L·di/dt. [Elektroda, DAVID CUTHBERT, post #21669975]
Why it matters:** This FAQ helps hobbyists get reliable high-current switching in DRSSTC primaries without overstressing the MOSFET or mis-simulating the transformer.
  • For: Tesla coil/DRSSTC builders, power electronics students, LTspice users.
  • Solves: “how do I fix low drain current,” safe gate drive, and transformer modeling.
How much gate voltage should I use on the W9NK90Z?
Drive the gate at 10–15 V. Avoid 30 V, even with a clamp. As one expert notes, “15 volts is really as high as anyone ever drives a MOSFET.” This range turns the device on hard without risking oxide breakdown. [Elektroda, DAVID CUTHBERT, post #21669977]
Why is my MOSFET only switching about 6–7 A?
With Rds(on) ≈ 1.1 Ω, a low drain supply limits current. One reply inferred about 7 V supply from 6.59 A, matching I ≈ V/R. Ensure your supply and load are modeled correctly before blaming the MOSFET. [Elektroda, DAVID CUTHBERT, post #21669975]
Does gate–source voltage alone limit current once the MOSFET is ‘saturated’?
No. Datasheet curves show high current at modest VGS when modeled correctly. The thread notes ~18 A at VDS 30 V and VGS 10 V, highlighting simulator error rather than a VGS ceiling. [Elektroda, Cody Gass, post #21669986]
Do I need a resistive load on the secondary to get primary current?
Yes. A resistive secondary load reflects as a primary load. Otherwise, only magnetizing inductance is driven, which limits real power transfer and observed primary current. [Elektroda, DAVID CUTHBERT, post #21669981]
What coupling coefficient should I aim for in a DRSSTC?
Use loose coupling. The discussion highlights low k so the secondary can swing to high voltage without excessive primary loading, preserving Q. A k around 0.2 was modeled. [Elektroda, DAVID CUTHBERT, post #21669981]
How should I model the Tesla transformer in simulation?
Include primary and secondary inductances and either a coupling factor or an explicit leakage inductance. Add realistic ESR for both windings and any topload or load components. [Elektroda, DAVID CUTHBERT, post #21669981]
My sim shows low current. How can I validate quickly in LTspice?
Try a similar MOSFET from the LTspice library and check that drain current ramps per V = L·di/dt. If that works, the earlier simulator or device model was at fault. [Elektroda, DAVID CUTHBERT, post #21669988]
Is 30 V gate drive safe if I add a 30 V gate–source Zener?
No. “30 volts of gate drive is never heard of and is a good way to break a MOSFET.” Use 10–15 V instead and keep decent gate resistance and layout. [Elektroda, DAVID CUTHBERT, post #21669977]
What L and C values were actually used in the thread’s primary tank?
A 2 nF capacitor in parallel with a 4.418 µH air‑core primary was discussed. These values set the primary resonance with the secondary. [Elektroda, Cody Gass, post #21669974]
What duty cycle and frequency were tried for switching?
A 95% duty cycle at about 100 Hz was simulated, with both duty and frequency adjustable for testing. [Elektroda, Cody Gass, post #21669976]
Can I replace the MOSFET with a square‑wave source to debug resonance?
Yes, as a modeling step. Use a square‑wave source to validate the transformer and tank first, then add the MOSFET driver stage afterward. [Elektroda, DAVID CUTHBERT, post #21669984]
Why did a direct square‑wave voltage source kill my resonance?
A hard voltage source enforces its waveform and can suppress tank oscillation, yielding high current but poor secondary voltage. Use a switch element instead. [Elektroda, Cody Gass, post #21669985]
What is a DRSSTC in this context?
It’s a MIDI‑interrupted Dual‑Resonant Solid‑State Tesla Coil. The interrupter modulates primary drive to create musical arcs and manage average power. [Elektroda, Cody Gass, post #21669980]
How do I estimate the current ramp in the primary?
Use di/dt = V/L. With correct L and applied voltage, you should see the expected linear current ramp during on‑time. Verify this in LTspice. [Elektroda, DAVID CUTHBERT, post #21669988]
What continuous current should I assume for the W9NK90Z here?
The thread cites typical continuous capability around 5–8 A. Design conservatively and check thermal limits and SOA in the actual datasheet. [Elektroda, Cody Gass, post #21669983]
Quick 3‑step: How do I sanity‑check my model before hardware?
  1. Build the tank and transformer in LTspice with L, C, ESR, and k/leakage.
  2. Drive it with a square‑wave source and confirm V = L·di/dt.
  3. Replace the source with a MOSFET and 10–15 V gate driver. [Elektroda, DAVID CUTHBERT, post #21669988]
