Driving a 120W Piezoelectric Transducer: Voltage, Impedance, Frequency Control?
294 16
How can I drive a 120 W piezoelectric transducer with a high-voltage transformer stage, and do I need frequency control because its impedance changes?
Drive the piezo with a transformer-coupled push-pull amplifier, because the transformer steps the voltage up and the transducer is not a plain 20-ohm resistor [#21669323][#21669327] Use two MOSFETs with inverted drive or a square-wave oscillator/timer interrupt around 42–47 kHz, keeping the frequency within the piezo’s rated tolerance [#21669323][#21669325] A real PWM/feedback loop is optional: it can stabilize the output if you sample the secondary, but a fixed oscillator such as a 555 or CMOS source can work if the frequency is correct [#21669325] The reply also suggested an IRFZ840 should be suitable, with about 5 V gate drive [#21669325][#21669329] For a 120 W design, the estimate given was roughly 65–67.5 V on the secondary and about 1.75 A, with the primary current much lower because the primary can look almost open-circuit at 42 kHz [#21669327][#21669329]
  • Questioning 400 V drive into 20 ohms
    #1 21669318
    Milad Rad
  • #3 21669320
    Milad Rad
  • #4 21669321
    Mark Harrington
  • #5 21669322
    Milad Rad
  • Timer interrupt method for 42–47 kHz push-pull drive
    #6 21669323
    Mark Harrington
  • #7 21669324
    Milad Rad
  • Square-wave oscillator and gate-drive voltage advice
    #8 21669325
    Mark Harrington
  • Transformer current requirement for 120 W output
    #9 21669326
    Milad Rad
  • 67.5 V secondary estimate from turns ratio
    #10 21669327
    Mark Harrington
  • #11 21669328
    Milad Rad
  • Primary and secondary wire gauge sizing for 120W output
    #12 21669329
    Mark Harrington
  • #13 21669330
    Milad Rad
  • Suggesting a trial-and-adjust transformer winding approach
    #14 21669331
    Mark Harrington
  • #15 21669332
    Milad Rad
  • #16 21669333
    Mark Harrington
  • Questioning frequency control and LP-BS technology use
    #17 21669334
    Milad Rad
The discussion addresses driving a 120W piezoelectric transducer, focusing on the required high voltage (~400V) and the apparent discrepancy with the radiation resistance (~20 ohms). It clarifies that achieving 120W output involves high voltage and current levels, typically requiring a transformer after the power amplifier stage for voltage step-up and isolation. Calculations suggest secondary voltages around 65-68V with currents near 1.75-2.5A to deliver the desired power, while the primary side current depends on transformer turns ratio and wire gauge. The primary winding behaves almost like an open circuit at ultrasonic frequencies (~42kHz), reducing current draw. Driving the transducer commonly uses a PWM or square wave oscillator at the transducer's resonant frequency (42-47kHz), with frequency accuracy important to maintain resonance and efficiency. Frequency control circuits or timer interrupts can be used to generate the drive signal, but strict frequency control is not always mandatory. MOSFETs such as the IRFZ840 are suitable for switching, provided gate drive voltages are within specifications. Wire gauge selection for transformer windings is critical to handle the required currents. Additional questions concern the necessity of frequency control for applications like algae removal and the nature of Low Power Bright Signal (Lp-Bs) technology, with no definitive answers provided. Reference materials and example circuits were shared to assist in transformer winding and drive signal generation.
TL;DR: To deliver ~120 W into a piezo, target 42–47 kHz and ~65–68 V RMS at the transducer; “frequency needs to be reasonably accurate.” [Elektroda, Mark Harrington, post #21669325]
Why it matters: Correct frequency, transformer ratio, and MOSFET drive prevent weak cavitation, overheating, and device failure for DIY ultrasonic cleaners and algae-removal builds.
Why do people mention “400 V” when my transducer looks like ~20 Ω?
This thread’s working solution used a transformer to step up to only about 65–68 V at the transducer, not 400 V. The key is matching frequency near resonance and selecting turns ratio for the needed secondary voltage and power, instead of forcing very high primary voltage. That approach delivered roughly 100–120 W without extreme voltages. [Elektroda, Mark Harrington, post #21669327]
Do I need frequency control or can I run it open-loop?
Hold frequency within the transducer’s tolerance band. The guidance here is 42–47 kHz, and the output “needs to be reasonably accurate.” Open-loop can work if stable, but include a means to trim or tune so drift does not move off target. [Elektroda, Mark Harrington, post #21669325]
How do I generate a 42 kHz drive with an AVR/Arduino?
Use a hardware timer interrupt to toggle two pins in antiphase every ~11.9 µs. 1) Configure the timer compare to overflow at 11.9 µs. 2) In ISR, invert both output pins. 3) Feed each pin to a MOSFET gate driver leg. This produces a ~50% duty, two-phase square wave at ~42 kHz. [Elektroda, Mark Harrington, post #21669323]
Is PWM strictly required, or is a square-wave oscillator fine?
A square-wave oscillator with accurate frequency works. You can also use a 555 or CMOS oscillator with an inverting path for complementary MOSFET drive. PWM with ADC feedback can stabilize voltage, but it is not required for basic operation. Watch the gate-drive limits. [Elektroda, Mark Harrington, post #21669325]
Why use a transformer, and how do I size the ratio?
You use the transformer to step up the low-voltage drive to the tens of volts the transducer needs and to provide isolation. Apply ES = EP × (NS/NP). In the example, the math yielded about 67.5 V on the secondary from a low-voltage primary. [Elektroda, Mark Harrington, post #21669327]
How much voltage and current do I need for ~120 W output?
One working point here is about 65 V and 1.79 A at the transducer, giving roughly 116 W. This shows that tens of volts at resonance can deliver power effectively, provided the drive frequency and transformer ratio are chosen well. [Elektroda, Mark Harrington, post #21669329]
What wire gauges should I use for the transformer?
In the example, primary current capacity drove the choice toward about 23 AWG for several amps and secondary around 26 AWG for roughly 1.8–2.2 A. Keep the same turns, change gauge to meet current. Verify temperature rise under load. [Elektroda, Mark Harrington, post #21669329]
Can I use an IRF840/IRFZ840 as the power MOSFET?
Yes, IRF840 class parts were suggested. With ~5 V gate drive, expect around 3 A per device from the transfer curve. Respect ±20 V VGS max and ensure proper gate drive and heat sinking. “Cant see why not IRF 840 should be ok.” [Elektroda, Mark Harrington, post #21669329]
Why does the primary seem like an open circuit at 42 kHz?
At the operating frequency and with proper tuning, the transformer’s primary presents high impedance except for the magnetizing and reflected load components. The contributor noted the primary “acts as open circuit at 42 khz,” which limits primary current. [Elektroda, Mark Harrington, post #21669327]
How do I set up complementary gate signals safely?
Drive one MOSFET with the timer output and the other with an inverted copy. Keep gate drive near 5 V for the devices referenced. Confirm dead-time if your topology needs it, and verify with a scope before connecting the transformer. [Elektroda, Mark Harrington, post #21669325]
How can I fine-tune resonance without complex control?
Trim the transformer turns by one or two to nudge the effective frequency point if your mechanical load shifts slightly. This simple tweak helps you land in the transducer’s tolerance band without closed-loop frequency tracking. [Elektroda, Mark Harrington, post #21669331]
What’s a simple, practical frequency math check?
Use period = 1/f. For 42 kHz, the period is ~23.81 µs, so toggle each half-cycle at ~11.9 µs. Implement this with a timer compare ISR and verify on a scope before power testing. [Elektroda, Mark Harrington, post #21669323]
Is frequency tracking mandatory for algae-removal applications?
Not mandatory here. Maintain accuracy within the 42–47 kHz band and include an adjustable element (timer preload or turns). That keeps performance acceptable without a closed-loop frequency controller. [Elektroda, Mark Harrington, post #21669325]
Any edge cases or failure risks I should watch for?
Excessive gate drive or inaccurate frequency can stress MOSFETs and reduce output. Keep logic-level drive near 5 V for the cited devices, and stay within the transducer’s tolerance band to avoid poor cavitation or extra heating. [Elektroda, Mark Harrington, post #21669325]
Does this thread cover LP-BS (Low Power Bright Signal) technology?
No. The discussion focuses on practical transformer ratios, MOSFET drive, and timer-based generation. LP-BS is mentioned as a question only, with no documented method or data here. [Elektroda, Milad Rad, post #21669334]
