Amplifying 35kHz–100kHz Signal to 50–150V for 10Ω Piezo Transducer Cavitation
492 13
Can I use a regular audio power amplifier to drive a piezo transducer with a 35 kHz to 100 kHz signal at 50 to 150 V for ultrasonic cleaning cavitation?
Regular audio power amplifiers are generally a poor fit for 35 kHz to 100 kHz operation, especially at high power and voltage. A better approach is to drive a power transformer with a square wave, then let the transformer’s inductance and the piezo’s capacitance form a tuned circuit that filters the waveform toward a sine wave and can raise the voltage at the transducer based on the Q of the circuit [#21661164] Adding known resistance can help control Q, though it costs some power [#21661164] One reply suggested that many audio amps may work only at reduced power, and that an 8-to-500 ohm transformer on a 200 W 8 ohm audio amp might work if the load is around 500 ohms and 50 W is needed [#21661165] The same reply noted a Hammond 1650WA transformer as a possible candidate, rated 280 W and full power up to 30 kHz, but that is still below your upper frequency range [#21661165]
  • #1 21661157
    Tony Altobelli
  • #2 21661158
    Jeff Evemy
  • #3 21661159
    Mark Harrington
  • Resonant impedance estimate for custom Langevin transducer
    #4 21661160
    Tony Altobelli
  • #5 21661161
    Tony Altobelli
  • #6 21661162
    Tony Altobelli
  • Transformer-driven piezo with tuned LC output
    #8 21661164
    Todd Hayden
  • Hammond 1650WA transformer as high-frequency match
    #9 21661165
    DAVID CUTHBERT
  • #10 21661166
    Tony Altobelli
  • #11 21661167
    Tony Altobelli
  • #12 21661168
    Mark Harrington
  • #14 21661170
    Tony Altobelli
The discussion addresses amplifying a 35 kHz to 100 kHz signal to drive a piezo transducer with approximately 10 Ω impedance at voltages between 50 V and 150 V for ultrasonic cavitation in deionized water cleaning applications. It is noted that the power requirements can be substantial, potentially reaching kilowatt levels depending on voltage and load, with typical ultrasonic cleaning systems requiring 40 to 75 W per transducer and about 100 W per gallon of fluid. Regular audio power amplifiers are generally not optimized for frequencies above the audio range and may not perform well at 35–100 kHz, especially at full power. A recommended approach involves using a square wave drive through a power transformer to create a resonant LC circuit with the piezo’s capacitance, which filters the waveform into a sinusoid and provides voltage amplification based on the circuit’s quality factor (Q). Controlling Q with series resistance can manage power loss and stability. A specific transformer example is the Hammond 1650 WA, rated for 280 W and designed for impedance matching (1900 Ω to 4–16 Ω) with full power operation up to 30 kHz, which might be adapted for this application. Additional resources include ultrasonic bath circuit schematics and explanations of Q factor for resonant circuits.
TL;DR: 280 W transformer rated to 30 kHz; "audio amps will not like 35–100 kHz at full power." Use a tuned transformer or dedicated driver to reach 50–150 V for piezos safely. [Elektroda, DAVID CUTHBERT, post #21661165]
Why it matters: This FAQ helps DIYers choose a workable, safe way to drive ultrasonic piezo transducers for cleaning without destroying an audio amp.
Will a regular audio power amp drive a 35–100 kHz piezo transducer?
Not well at full power. Most audio amps roll off above ~20–30 kHz and can overheat or oscillate when loaded by piezo capacitance. As one contributor put it, "audio amps will not like running full bore at 35 kHz to 100 kHz." Use a purpose-built driver or transformer-coupled stage instead. [Elektroda, DAVID CUTHBERT, post #21661165]
How much power do typical ultrasonic cleaning transducers need?
Plan for approximately 40–75 W per transducer at resonance. Ultrasonic Langevin stacks often need high drive voltage to achieve the required acoustic power. Budget your driver and power supply with margin for mechanical loading and thermal limits. [Elektroda, Tony Altobelli, post #21661161]
How do I size power for my tank (rule of thumb)?
Use about 100 W per gallon of fluid. For example, a 40-gallon tank will need around 4,000 W total electrical input distributed across multiple transducers and drivers. Provide headroom for start-up and detuning under load. [Elektroda, Tony Altobelli, post #21661162]
What’s a practical driver topology to reach 50–150 V at 35–100 kHz?
Drive a power transformer with a square wave and let the transformer inductance and the piezo capacitance form a tuned LC. The LC filters the square wave into a near-sine and boosts voltage by the network’s Q. Add series resistance to control Q and protect the transducer. [Elektroda, Todd Hayden, post #21661164]
What does Q mean in this context?
Q (quality factor) quantifies resonance sharpness and energy storage versus loss. Higher Q increases voltage gain in your LC network but narrows bandwidth and raises risk of overvoltage. "Q factor" definitions cover bandwidth, energy, and damping relationships for resonant systems. [Q factor — Wikipedia]
Can I use an output transformer to match an audio amp to a piezo load?
Yes, with care. One approach proposed an 8 Ω to ~500 Ω match using a high-power output transformer. Example: Hammond 1650WA, 280 W, 1.9 kΩ to 4–8–16 Ω, with full-power bandwidth to 30 kHz; derate above that. Ensure thermal headroom and check stability. [Elektroda, DAVID CUTHBERT, post #21661165]
Is there a reference circuit for an ultrasonic cleaner driver?
Yes. See the RepairFAQ ultrasonic bath circuit referenced in the thread. It illustrates practical piezo drive methods and is a good starting point for scaling and experimenting before custom designs. Validate parts ratings for your target frequency and voltage. [Elektroda, Mark Harrington, post #21661163]
How do I characterize my Langevin transducer before building the driver?
Sweep frequency with a function generator and observe current/voltage to locate resonance. The OP notes building a Langevin and expecting resonant behavior; plan to verify with a scope once your test gear arrives. Record impedance versus frequency to guide matching. [Elektroda, Tony Altobelli, post #21661160]
How do I prevent overvoltage from a high‑Q tuned network?
Insert a known series resistor to reduce Q and limit voltage rise at resonance. This sacrifices some efficiency but improves stability and protects the piezo and transformer. It also broadens bandwidth for easier frequency tracking. [Elektroda, Todd Hayden, post #21661164]
Any specific transformer models or costs to expect?
One suggestion was the Hammond 1650WA output transformer, rated 280 W with full-power response to 30 kHz. A noted price example was about $323 via a major distributor. Confirm current pricing and consider derating above 30 kHz. [Elektroda, DAVID CUTHBERT, post #21661165]
Quick how-to: build a simple test driver for a piezo stack?
  1. Generate a square wave at the target frequency and feed a suitable power transformer.
  2. Let the transformer inductance and the piezo capacitance form a tuned LC at resonance.
  3. Add a series resistor to control Q; monitor voltage and temperature under load. [Elektroda, Todd Hayden, post #21661164]
Edge case: What happens if I drive 150 V into a 10 Ω load?
That implies 2.25 kW (V²/R), which is excessive and unsafe for small cleaners. Thermal and electrical limits will be exceeded. Re-evaluate the actual piezo impedance at resonance and design for realistic power levels. [Elektroda, Jeff Evemy, post #21661158]
Can I scale up the RepairFAQ bath circuit for higher power?
Yes, but validate transformer core size, switching devices, and heat dissipation. The OP planned to scale that approach; do staged tests and watch resonance peaks. Always verify with scope measurements before full-power operation. [Elektroda, Tony Altobelli, post #21661166]
Is 35–100 kHz a reasonable target for cavitation cleaning setups?
Yes. The project goal outlined this band for driving piezo transducers to create cavitation in deionized water. Ensure your driver, transformer, and transducers are characterized across this span and derate components appropriately. [Elektroda, Tony Altobelli, post #21661157]
