HC-SR04 Arduino: Can I Measure Frequency Changes to Identify Materials?
357 6
  • Questioning frequency-based material recognition with HC-SR04
    #1 21669353
    Kazem Chma
  • HC-SR04 cannot detect materials by frequency changes
    #2 21669354
    Mark Harrington
  • Ultrasonic leak detection in pipes with 40 kHz sensors
    #4 21669356
    Kazem Chma
  • Gas sensor mistaken for ultrasonic transducer
    #5 21669357
    Mark Harrington
  • #6 21669358
    mark Spend
  • #7 21669359
    Kazem Chma
The HC-SR04 ultrasonic sensor operates by emitting a fixed 40 kHz ultrasonic pulse and measuring the time delay of the echo to determine distance. It is not designed to detect frequency changes or variations in the ultrasonic signal, as the transducer resonates within a narrow frequency band (38 kHz to 42 kHz). Therefore, using the HC-SR04 to identify different materials based on frequency shifts is not feasible. For material detection, electromagnetic methods such as Very Low Frequency (VLF) metal detection using transmitter and receiver coils are more appropriate, as they detect changes in magnetic flux rather than sound waves. Ultrasonic sensors can be used for leak detection by measuring reflected sound waves, but they do not detect frequency changes caused by different pipe conditions. Gas sensors, which may look similar to ultrasonic sensors, operate on different principles and are used for detecting leaks of gases rather than ultrasonic frequency shifts. For DIY ultrasonic leak detection, narrow beam ultrasonic transducers can detect fluid levels or leaks by analyzing echo reflections rather than frequency changes.
